Crotchety Old Bastard
RarlyL8's Avatar
Active Exhaust muffler on now is a prototype, production units will have the valves rotated 45° towards the front of the car.
Old 11-01-2019, 02:29 PM
El Duderino
tirwin's Avatar
Brian, I sent you an email to inquire about pricing and availability with my proposed configuration.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 11-04-2019, 11:50 AM
Eva
911SauCy's Avatar
Originally Posted by RarlyL8 View Post
Been running the MKM34AE Active Exhaust muffler setup on the SC for a few weeks now and man I love it. The 1.5" primaries on these headers are a good size for the stock 3.0L engine. I haven't had it on a dyno yet but the power increase is noticeable compared to OEM early header/exchangers and a stock early dual inlet muffler. You can see a peak of the OEM exchangers sitting under the car during the swap out.
This work is simply art.
Tremendous product
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 11-04-2019, 12:56 PM
Looks like a must have for XMAS. Thanks alot Brian. I have your GT3 muffler and rear Valance. I guess I'm going to put your headers on my XMAS list.
Old 11-04-2019, 01:15 PM
Nice setup. How do you get through smog in LA?
Old 11-05-2019, 10:58 AM
1971 911T. No smog required
Old 11-05-2019, 11:45 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Shape/layout of these looks very similar to the Bursch headers? I recognize the stainless construction, welds, F1 collectors of yours are a major improvement. Just wondering if the Bursch layout is mimicked here
Kevin L
'86 Carrera "Larry"
Old 11-05-2019, 02:09 PM
3rd_gear_Ted's Avatar
My understanding is that exhaust gas flows better when kept hot.
The final pipe section is close to rear of engine and is operating @ 900 degrees
So, why is the final collector pipe section not wrapped with thermal cloth????
1980 911 - Metzger 3.6L
2016 Cayman S
Old 11-05-2019, 02:51 PM
Brian how much if any of a gain in HP over SSIs?
Old 11-11-2019, 03:23 PM
H-viken's Avatar
Or over your previous model?
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 11-12-2019, 12:58 AM
RarlyL8's Avatar
When designing these headers I purchased 3 different popular models and mounted each to see which basic tubing route I linked best, and yes Bursh was one of them. I liked the layout of the tubes but that was about it. All the "cheap" headers had either the crappy flat collectors or stamped triangle merge that dumped all 3 tubes into a hole. None of them were equal length even though some are advertised as such. I smoothed the bends on the primaries and changed the path slightly to clear everything while butting up as close as possible to the engine for ground clearance. The length of the primaries was changed to 30.5" +/- 0.25" which is ideal for 3rd pulse harmonics of the medium displacement air cooled engines. Of course our F1 style collectors are used as well. The end product looks Bursh-esque at first glance but they are much different in the details.
Thermal cloth destroys the metal and looks ugly for the tiny increase you might see on a street car. Better to thermal coat the stainless if desired.
I haven't had the car to the dyno to compare against early exchangers or SSI yet. All the improvements made are tried and true, and the butt dyno can attest. We sell to many race shops who do a lot of dyno work, I am sure I will get that data as well.
Our medium length RSR headers were designed specifically for the 3.2L Carrera, these 1.5"OD long tube headers are designed for the 2.4L-3.0L engines. The Carrera headers utilize 5th order pulse timing for the Motronic engine at 5800rpm peak HP and have port matching 38mmID primaries (1.63"OD tubing). They will still be offered for that application.
Old 11-12-2019, 06:25 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Thanks for the clarifications. I agree the stamped triangle collector on the Bursch headers is a bit crude. But it seems to be a little bit cleaner in funneling than the well known SSI/George's/GT Racing chopped pipe flat collector that was copied from the original Porsche exhaust dating back to the 60s?
I didn't know your other headers were built specifically for the 3.2 Carrera engine's specifics. That's good to know!
Since we've got your ear, ever heard what prompted these BBE headers to arrive to market? Just seems odd that for years their product was basically all long tube headers and their proprietary rectangular muffler that always split. Then in the recent past these "early" headers came along. Seems like Patrick likes to use them. Maybe they finally decided to make something that fit the typical banana mufflers?
Kevin L
'86 Carrera "Larry"
Old 11-12-2019, 12:19 PM
RarlyL8's Avatar
Can't say what prompted the design change of the above headers but we've always used the OEM dual inlet muffler position as it gives you muffler options. The goal is to get what you want, not force on you what we have.
The outboard primary design as seen above is one I rejected as the passenger's side gets too close to the main oil tank line.
Old 11-12-2019, 06:17 PM
