Moses's Avatar
3.6 heat. Crossover solution...
I will be using one of Thom's RS bypass tubes but need to split the outflow. Well, I tried to fabricate a "Y" pipe for heat crossover. My solution was not nearly as clean as Thom's (pictured). So I got back on the net and found that many of the aircraft supply places that sell SCAT tubing also sell "Y" pipes specifically to join SCAT tubing. Just thought I'd share what looks like a clean solution.
Old 03-23-2003, 08:35 AM
Moses's Avatar
Sorry, here is the "Y" pipe:
Old 03-23-2003, 08:39 AM
Bill Verburg's Avatar
Any particular reason you are not using the 993 ducts to connect to the heat exchanger inlets? Not enough room w/ those mufflers?
Bill Verburg
Old 03-23-2003, 09:56 AM
Moses's Avatar
I don't have any 993 ducts. Don't know if they'll fit. Definitely no room for the stock heater blower. Planning on using an RS style heater blower bypass.
Old 03-23-2003, 10:36 AM
Moses, exactly where did you find that nice welded-aluminum Y pipe? I tried Aircraft Spruce and Wicks and couldn't find anything. It's exactly what I need, to replace the plastic plumbing-fitting kludge I've got in there currently.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 03-23-2003, 11:30 AM
Moses's Avatar
This is one of many places I found it. $21.95
http://www.chiefaircraft.com/cgi-bin/hazel.cgi?action=serve&item=/Aircraft/Hardware/Heating.html
Old 03-23-2003, 12:50 PM
Here is a diagram of the 993 heat ducts, they have nothing to do w/ the blower
The transverse tube #8 fits above and behind the stock cat.
Bill Verburg
Old 03-23-2003, 01:10 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Bill,
#8 is $$$$ if you have to buy it new from Porsche. But it sure would be nice to have it. Paul is making something similar from fiberglass.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 03-23-2003, 03:31 PM
