1971 2.2T Tool roll/ kit - restore or sell?
Hi
My 1971 2.2 T passed away a few years ago, but I still kept hold of the tool kit and jack. As you can see from the pictures they have some heavy patina
I know I am at least missing the plyers and 3 open ended spanners, plus I may have picked up an extra screwdriver or two but as they are made in West Germany I have left them in the photos. The spanners are the correct "drop forged" spanners, but it will be hard to see that in the photos through the rust.
So my questions are should I get these soda blasted and then nickel plated, plus repair the roll itself, or do I try to sell them as they are? Can someone give me an honest view of the value too?
They came from a Californian 1971 2.2T, which was fire damaged.
Thanks in advance for any thoughts.
1971 911 2.2T
Old 07-16-2019, 10:14 AM
proporsche's Avatar
those 2 screwdriver on right are not correct..
I would ,in your case take my time-no hurry- and get it cleaned..and get the other missing pieces.
I think i might have the pliers ..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-16-2019, 11:38 AM
Allen_70S's Avatar
B. Johnson’s book lists the following items for ’69 and ’70 tool kit (71 has to be the same). It matches my tool kit which was in the car when purchased in 1978. (Few years to be corrupted. The plastic bag for fuses was gone, I replaced it with a small plastic box.
It is my opinion that completing the kit and restoring the contents will be way more expensive than you could recoup by selling it.
Bag
Spark Plug Wrench with Pin
19mm Wheel Nut Wrench
8 x 9 mm Open-end Wrench
10 x 11 mm Open-end Wrench
12 x 13 mm Open-end Wrench
14 x 15 mm Open-end Wrench
17 x 19 mm Open-end Wrench
19 x 22 mm Box Wrench
Screwdriver
Phillips Screwdriver
Pliers
Fan Belt
Plastic Bag with 5 Fuses
Fan Belt Wrench
Allen Wrench for Oil Drain Plug
Jack
Old 07-17-2019, 08:46 AM
Thanks Allen_70S for the list of contents, I appreciate it.
Any thoughts on what it might be worth with the Jack to sell?
Thanks again
1971 911 2.2T
Old 07-17-2019, 08:54 AM
The 19/22 box wrench is worth some money, so are the screwdrivers (assuming they will clean up). Somebody would buy the spark plug wrench and hex wrench combo for $50-$75. The rest is nickel and dime stuff, as-is.
Old 07-17-2019, 09:18 AM
proporsche's Avatar
still... i would clean and get it together....i have sold the flat screwdriver back in the 2009 for 160 bucks ..the close wrench 19-22 i got 140 bucks..does the allen 10mm has any writings on ,it like 911 DIN??
Old 07-17-2019, 11:19 AM
Go onto EBAY and look for Porsche 911 tool kits. Look at the insane prices for these kits! This should encourage you to clean up these tools, maybe buy a reproduction tool bag and make over one grand if not two grand!!!!!!
Bob
Old 07-17-2019, 11:24 AM
proporsche's Avatar
when you decide as I said.... i have the pliers..Solingen in on them..looking on the prices now do not sell the kit cheap...
Ivan
Old 07-17-2019, 11:42 AM
Thanks again Proporsche, Mocker, Allen_70S, Sunroof - great advice.
Just checked the prices on ebay and some of them are eye watering, I'm glad I'm not buying!
So should (for a 1971 car) the pliers be HAPEWE or SOLINGEN on them?
The open ended wrenches I have are marked Drop Forged Steel Germany on one side and nothing on the reverse. But from looking at some kits on ebay some have Alloy Steel on the reverse. What should mine be if I'm trying to build a set?
The 19/22 Box wrench has CHROM -VANDIUM on it and nothing on the reverse (should this one say Drop Forged Steel too?)
The allen wrench is marked DIN 911 SW10 KLEIN W.GERMANY, fan belt wrench is marked P208 and Spark plug is KLEIN 21.
Thanks again for all the stupid questions, but I'd rather make sure I have a period correct set before trying to sell it.
1971 911 2.2T
Old 07-18-2019, 02:14 AM
Still available ?
Hi.
Need the P208 alternator open wrench and the 19-22 open wrench tools.
Still available ?
Thank you.
Best,
Greg
Old 02-18-2020, 12:02 AM
Originally Posted by gregoiregamba View Post
Hi.
Still available ?
Thank you.
Best,
Greg
Hi Greg,
Would you have a drop forged 17/19 open end for sale?
Many Thanks
Old 06-23-2020, 01:36 PM
