Wildman Emeritus
A/C Electrical Help????
I need some electrical help for my A/C. It was running fine and just stopped while fan was on high.
Here's what I have done: ( I am basically an electrical idiot and must have worked for Lucas in a previous life)
Fuse- first thing checked.
Relay switched with known good relay
Fan Blower switch swapped for known good switch. Bentley pretty much points here
Verified voltage to fuse block
Verified continuity in resistors in footwell
No blower motor function still and I do not believe the clutch is engaging.
Still no go. So:
How do I jump the blower motor to verify it is functional or meter check it?
How do I verify there is power to the switch - which terminals do I check? I assume that if the switch has power the problem is between the switch and blower
And where else and how else to check the system? Bentley is not exactly definitive for troubleshooting the system electrically.
Like to have it functional before IMSA at Road America in 2 weeks and just be able to drive it comfortably.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 07-21-2019, 11:51 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
This will shut down you A/C.
Did you check both sides of the fuse?
pm me as needed.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-21-2019, 12:06 PM
Wildman Emeritus
Have continuity thru fuse and holders so I assume the fuse is good.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 07-21-2019, 12:44 PM
Wildman Emeritus
Bump.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 07-22-2019, 05:33 AM
Did someone add an evaporator relay and fuse?
PS: Photo stolen from 86 911 Targa
Old 07-22-2019, 06:46 AM
fuse.
Do you have 12v on both sides of the fuse
when the A/C is active?
Gerry
pm me as needed.
1986 911 Targa.
Only in L.A.:
Old 07-22-2019, 07:44 AM
Wildman Emeritus
SOLVED!!!!!!!
Thanks to Raw911 and the rest of you for your assistance.
It was the evaporator fuse which I replaced and Voila!!!!
As I was doing it, I remembered replacing it long ago and how tight it was to get the fuse in with my giant hand in there with the correct angle for fuse placement.
Man, I feel like an even bigger electrical idiot now. However, I aspire to be an electrical moron in the future
Cleaned out a big mouse nest from the Smuggler's Box which could possibly have impeded airflow and led to high current draw. We shall see as I use the system. Man, I hate freaking mice. I fight them at my place in N. Wisconsin and now, here. Not enough owls, hawks and wolves.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 07-22-2019, 08:00 AM
