Send a message via AIM to flyingplatypus
Power drain problem, need help identifying the source
Can you help me identify where these positive leads head to? They are both shorting out @ ~1.4A each.
'84 Carrera 911 euro (Guards Red) "Jessica"
Old 07-30-2019, 04:47 PM
ROW '78 911 Targa
timmy2's Avatar
Single red likely goes directly to the fuse panel for constant powered loads.
The double red likely goes to the ignition switch for switched power loads.
Check the power window relay, it likes to hang...
Best method is to leave everything connected normally and pull fuses until the load (drain) goes away.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-30-2019, 05:11 PM
I'll check that next. I pulled every single fuse from the panel and it still drew but at less draw. Do you know which one it is in an 84?
Old 07-30-2019, 05:45 PM
Nevermind I pulled them all and no change. The left window wont go up though. Might be related. Any way to disconnect the windows completely?
Old 07-30-2019, 06:02 PM
ROW '78 911 Targa
timmy2's Avatar
Isn’t the Power window relay on the front fuse panel?
Dennis
Old 07-30-2019, 07:01 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Residual draw.
What is the current draw when you pulled all the fuses.
Not sure, but, I don't think the DME is fused.
Also, other items on the 3.2 cars are not fused.
The typical non-use draw on our M/Y 86 is 150ma.
G.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-30-2019, 08:16 PM
1. Power window relay is behind the leftmost gauge, also 'reachable' from the frunk, see 'fensterheber' relay in pic on fuse 1 of bank 2 in the front fuse box (25A)
2. Other directly connected items I know of
- starter motor & alternator B+
- DME relay under seat
- from the DME relay, 'step 1' : ICV, DME, fuel injectors
- from the DME relay, 'step 2' : lambda sonde (O2 sensor) heater
- anything directly connected to pin 30 of the key contact (without passing via fuse box)
or any of the pins that get connected to this 30 when turning the key
such as :
dashboard instrument lights on pin 58a of light switch (!) - I inserted a 3A fuse here to be safe !
ashtray light (!)
possibly radio (if not installed correctly)
Old 07-31-2019, 01:56 AM
Just to clarify on a MY88
Old 07-31-2019, 02:06 AM
T77911S's Avatar
you said it drew less, how much is less
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-31-2019, 10:43 AM
Your best option, other than replacing stuff, is to get the complete electrical diagram in FrankM's post, then trace the path of the (2) red wires described.
The 4.0 and 6.0 wires identified; If you disconnected all fuses in turn with no indication from your ammeter, then those circuits are unfused. I'm not conversant with an '84, but those circuits might include:
- Heater fan motors (typical short circuit items)
- Starter solenoid and starter
- Alternator
BTW:
6.0 wire is equivalent to about a 9 AWG ga. wire size
4.0 wire is equivalent to about a 11 AWG ga. wire size (the two red wires in you photo might be these)
Others in the know about your MY 911 can provide more info.
Sherwood
Old 07-31-2019, 11:16 AM
I stumbled upon 911C1's website (911c1.de) and got the PDF from the site.
It is a 1988 schematic and I own a 1985 myself but haven't been able to find the workplace manual nor the diagrams for a 84-86 911.
I tend to use the Bentley manual to look at the part of the electrical system that I am interested in and the use the wiring diagram to find the details. The Bentley manual also highlights the differences between the build years.
Still looking for a PDF of the 84-86 911 (non-turbo) workplace manual, and not the eBay offers going 900 - 1200 EUR for the printed version.
Old 08-01-2019, 02:46 AM
