piscator's Avatar
Guys, thanks very much!
URO, that's good to know!
Pat, you’re right, it’s a big topic; but I do have a better sense of things, just from this thread!
Fan, thanks for your clearing that up! Polyethylene is the plastic I was referring to and couldn’t remember. Rotomolding was the only reference I could bring to mind. When I helped repair my friend’s kayak, I read about those special adhesives and the welding. That was quite interesting!
What my friend and I did (based on another repair website) is cut some polyethylene a little larger than the crack and ‘melted’ it into place with a heat gun – both inside and outside. It’s held up well, but I have trouble trusting so modest a repair.
Paul, great explanation! The ‘model plastic’ reference for thermoplastic painted a perfect picture. As a kid, I spent hours in my buddy’s basement making dune buggies and dragsters, using the tube shaped plastic from the frames that the model parts came attached to. We’d cut a length to fit, melt an end with a candle and stick it where we wanted – no glue. We made some neat stuff!
‘Thermoset plastics give off heat as they cure...” – that’s interesting. That, of course, makes me think of all the fiber-glassing I do. I don’t know if, technically, catalyed resin qualifies as thermoset plasitc, but it does get hot while curing. And, cured resins don’t burn unless you subject them to considerable heat. I built my kitchen counters in hardwood and finished them with six coats of a slow curing epoxy. I don’t make it a practice, but they’ve endured the occasional ‘hot pot with no place to put’ – pretty well.
All the technical stuff that we get into on this website fascinates me and I really appreciate learning from everyone!
Robert
"A man must consider what a rich realm he abdicates when he becomes a conformist." ~ Ralph Waldo Emerson ~ (thanks to Pat Keefe)
Old 08-13-2019, 08:08 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Originally Posted by piscator View Post
Since we're on the subject, I might as well ask. Would there be a market for air-boxes made in carbon fiber?
Making a mold from a donor box is time consuming but not difficult. I thought about doing that when I repaired my evaporator box. One shop where I buy supplies, makes molds to do short runs of parts for the Navy. Their work is impeccable!
I'm not sure it's something I'd want to get into, but I am curious to know what you guys think. (If this is too much a thread derail just ignore me).
BTW: Carbon fiber is over-rated. In many of the applications where I've seen it used it's really not necessary. Carbon fiber and Kevlar are strong, but not a whole lot stronger than fiberglass. They are lighter than 'glass, so great for making canoes, tennis rackets, and race car parts. But they're also brittle and prone to cracking. Fiberglass is the hands down winner for toughness and longevity. The fiberglass shock mounts I made for my truck are as strong as steel and will outlive the frame by decades.
Hey,
I tried to sell my Webb Industries SS CIS box, here and and on eBay. Not a whiff of interest.
Webb Industries CIS airbox
Much better than carbon fiber, was machine quality fabrication. Carbon fiber is difficult to manufacture, look at the guy who was trying to sell CF hoods and lids(Todd), if you think that a CF airbox will sell for less than a thousand bucks, good luck, I had a CIS car, and have also fabricated with CF. The market will dictate viability, CIS cars are a declining breed, when you can buy sophisticated EFI, for 1/4 the price of PMOs and other systems. The market is severely limited.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 08-15-2019, 09:48 AM
Reiver
Reiver's Avatar
Question on the airbox...is the 78/79 large port airbox the same as used on the 82/83 large port SC Euro?
De Oppresso Liber
Strength and Honor 5th Legion
Old 08-15-2019, 10:09 AM
Intake runners........
The US spec ‘78-‘79 SC’s have 38-mm ID intake runners (-4R). Same as the RoW/Euro SC’s (‘78-‘83) with -4R intake runners. The SC’s with lambda (US/CAN/Japan) have the smaller intake runners (34-mm ID) (-2R).
Tony
Old 08-16-2019, 03:51 AM
Originally Posted by ClickClickBoom View Post
Hey,
To those that are interested, the airbox went with the Crunchmobile, so it's out there. As a fabricator, there is $3-4000.00 thousand worth of R&D and welding into that airbox, if you can buy one it's worth whatever they might be asking. CIS is a good system for a stockish car, that airbox eliminates a couple of prickly problems in the airbox area. The blowoff valve is weapons grade and the welding is approaching art.
Old 08-18-2019, 09:35 AM
I remember having to glue porcelain, too, but only when repairing the bathroom. Because there were difficulties just the same with the fact that the standard glue for some reason did not take anything there and had to certainly come out of the situation non-standard. Used to look on the Internet, what can be glued, found very useful information on this subject. It just described in detail, which is better to pick up glue for porcelain and toilet repair https://gluefaq.com/best-glue-for-porcelain-toilet-repair/ most successfully. Fortunately, it was possible to find the right glue quickly, for example, the same Gorilla Super Glue Gel, it helps to glue such damages on different surfaces as quickly as possible, porcelain is very fast. This makes me very happy, as the standard glue didn't help me in any way. So be sure to take a look and see, I think it's definitely not superfluous.
Old 07-19-2020, 12:02 PM
