5 now. Although in reality I’m sure it’s a few hundred based on the number of views.
I’m in awe. I bought all the metal working tools but don’t know how to use them. Clearly I could’ve gotten by without them. Keep up the good work and ,and man you sure are persistent. Tony |
Rennch on YouTube
Thanks. Plenty of time to work on it since I’m pretty much stuck at home these days. What metal working tools did you buy? Sent from my iPhone using Tapatalk
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Rennch on YouTube
This one really kicked my ass.
I had to cut out a ton of the race car fabrication to properly make the mount for the G96 transmission. It was a huge PITA, and a 100+ F heat wave didn't help!
Rennch on YouTube
![]() ![]() ![]() Sent from my iPhone using Tapatalk
Rennch on YouTube
In video 23, I carried on with the process of shaving the drip rails. Cut, grind tack grind tack grind cut, etc...
![]() ![]() ![]() ![]() And...I caught a couple things on fire, lol. ![]() Sent from my iPhone using Tapatalk
Rennch on YouTube
And here's the video:
Rennch on YouTube
DIY wrencher
Love your approach on this build Mike, not afraid to follow your vision and figuring things out as you go! I imagine that it helps that you got the car fairly cheap and that it was already extensively cut and modified, so you are most likely increasing the value with your additional mods to make it streetable with a cool non-GT and retromod look.
Rennch on YouTube
Rennch on YouTube
Ran the coolant lines through the tunnel. Will be combining heat shielding with modern techniques and products to mitigate cabin heat:
![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk
Rennch on YouTube
And here's the YouTube vid:
300hp 1800lbs is the goal
It will be interesting to see how you get those oversize coolant lines out of the steering rack area. You still need 2 fuel lines going through the tunnel.
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
Rennch on YouTube
996 Shifter Install
Was pretty challenged trying to install the 996 cable shift 6 speed shifter into my G96-equipped 69 911, but I got it done!
subd
Subi 911
Great thread, subscribed!
Behind the wheel in my US imported 81 SC with 3.2L swap. |
Entrepreneur
Good videos and sub'd.
I hope that you can get a better welder to get you those dimes on your welds. Keep it up and keep going with the build. You are doing it right with some trial and error and moving forward with figuring it out Mike!
Detailing Porsches and others https://www.instagram.com/autosalonworks/ 02 WRX Wagon |
Rennch on YouTube
Ha ha...it’s DEFINITELY not the welding machine. Sent from my iPhone using Tapatalk
Entrepreneur
Rennch on YouTube
I have a really nice Lincoln welder. I'm not sure what you're getting at here.
Entrepreneur
