LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
Under the radar
Trackrash's Avatar
What dimension are you looking for? The problem is when I post a jpg, Pelican shrinks the picture. Maybe someone can link to a better file. For example this is 3264 pix wide on my computer.
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-06-2019, 09:30 AM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Can you email it? 2syllableword at gmail.
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 12-06-2019, 09:32 AM
I would rather be driving
jpnovak's Avatar
Those look like non-turbo trailing arms that have been relocated rearward and upward at the forward pickup point due to new mounting brackets.
You will likely find it easier to relocate the flare opening than to undo all that custom suspension fab work.
IMO the longer wheel base by moving rear wheels back is a GOOD thing.
Old 12-06-2019, 09:54 AM
Either way you’re in for some work to get that wheel in the right place.
Old 12-06-2019, 10:11 AM
Rennch on YouTube
rennch's Avatar
That’s the truth!
Michael O'Neal -
Old 12-06-2019, 10:13 AM
If you’re going to fit new flared arches for wider tyres then maybe you can push those backwards and fill in the rest?. You can fill in the torsion bar hole while you’re at it.
Old 12-06-2019, 10:14 AM
jpnovak's Avatar
Leave the torsion bar hole. Cut the QP behind the torsion bar hole. Offset cut the new flare and then slide it back. Plenty of metal to make up one inch there. Challenge will really be aligning the curvature of the top of the QP/flare.
Old 12-06-2019, 10:30 AM
Under the radar
Trackrash's Avatar
Let's try again.
Gordon
Old 12-06-2019, 03:34 PM
Rennch on YouTube
rennch's Avatar
Let's try again.
Thank you! I might need to order the real copy of this! Do you have a higher resolution version you might be able to email me? I sent you the email in an above message.
Michael O'Neal -
Old 12-06-2019, 08:17 PM
Rennch on YouTube
rennch's Avatar
New YouTube video is live! Replacing quarter panels on your 911:
https://youtu.be/qycXDigWHEA
Michael O'Neal -
Old 12-06-2019, 08:18 PM
Rennch on YouTube
rennch's Avatar
Hey dudes. I have two new videos. One comes out tomorrow.
My latest video about the abandoned 1969 Porsche 911s race car that I'm converting back into a street car. This video is about fitting and installing the rear decklid latch panel, but first I have to cut and grind away the race-modified rear engine quick release mounts. This is the 6th video in the series, so if you're looking for some cool Porsche content to binge on, now's your chance.
Latch Panel, video 1: https://www.youtube.com/watch?v=EejDXRjhu_g
And here's the link to the whole playlist: https://www.youtube.com/playlist?list=PLpd6y-3BC1Z4BJ4KQ36wQDshyliZHyYfM
Michael O'Neal -
Old 03-25-2020, 05:07 PM
Rennch on YouTube
rennch's Avatar
Part 2 of my rear latch panel fabrication and install is posted on YouTube: https://youtu.be/ZmAgqKuW0CM
Michael O'Neal -
Old 03-27-2020, 07:35 AM
drb930's Avatar
The 993 is the same WB as any 69-89 911. WB was not increased until 996.
RUF has a 993 that they have pushed the front wheels forward, and the rear wheels rearward.
The article is here - https://www.excellence-mag.com/issues/240/articles/200-mph-classics
He gets the arches correct and it makes the car look much more modern.
Might be some inspiration for your rear arches.
BTW really enjoy your videos.
Are you going SBC V-8?
Thanks,
Dave
3 Things To Live By - You can't be Too Rich, Too Thin, or have Too Much Horsepower!
Old 03-27-2020, 08:55 AM
drb930's Avatar
Here’s a picture of the 2 WB’s, Orange car is the longer WB.
Thanks,
Dave
Old 03-27-2020, 09:33 AM
Rennch on YouTube
rennch's Avatar
No...at the moment I'm trying to decide between two powerplants. One is Japanese, and one is Porsche. They are both flat 6's though.
Michael O'Neal -
Old 03-30-2020, 07:28 PM
Rennch on YouTube
rennch's Avatar
Passenger Quarter Panel Install
I got my passenger quarter panel trimmed pretty darn close. Am curious about the door gap. Can I dial it in with a little hammer/dolly on the inside if I want to move it a millimeter or two?
Here's the video of the process/install:
https://youtu.be/vuqPQLhaorA
Some Pics:
Michael O'Neal -
Old 04-01-2020, 05:39 PM
Rennch on YouTube
rennch's Avatar
Also..I'm not exactly sure what to do about the existing lead filler. I may need to delete some of it so I can get to the metal to weld it. On the grey ghost, I hit it with a propane torch and it melted away. I'm planning on doing lead filler on this car for the drip rail delete, so I could probably do it here as well.
Michael O'Neal -
Old 04-01-2020, 05:40 PM
Rennch on YouTube
rennch's Avatar
Cleaned up the welding interfaces.
Michael O'Neal -
Old 04-01-2020, 07:32 PM
Rennch on YouTube
rennch's Avatar
Here's the full playlist from the beginning, now that I know how to properly embed the vids:
Video 1, the unveiling:
Michael O'Neal -
Old 04-02-2020, 12:24 AM
Rennch on YouTube
rennch's Avatar
Removing More Race Car Bits:
Michael O'Neal -
Old 04-02-2020, 12:27 AM
Tags
build thread
