Rennch on YouTube
Project Outline and plan:
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Rennch on YouTube
Front Bumper Rust Repair and cutting into the custom race "nose" of the car to fit the front fenders.
Rennch on YouTube
The Restoration Design panels have arrived! Initial fit of the rear quarters, and stripping off some of the race bits to make them work.
Rennch on YouTube
Rear Panel Install Part 1!
Rennch on YouTube
Rear Latch Panel Part 2!
Rennch on YouTube
Final Quarter Panel Fitment, Passenger Side!
Rennch on YouTube
Finished off with some weld thru primer today.
![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk
Rennch on YouTube
Yea...that's what I was thinking too. Plus I want to learn lead filling...I think it's a lost art.
I just saw this car in person and it's the real deal although I don't envy the amount of work ahead.
And money. But if it turns out to be close to the concept it will be a world class build.
Rennch on YouTube
I'm hoping because it's going to be mostly DIY that it won't be a tremendous amount of money. Famous last words.
Rennch on YouTube
I've just uploaded the latest video of my 69 911S Blasphemy Build, where I try to figure out if I can use my flux core welder to patch some unseen body panels.
Rennch on YouTube
Posted another video today wrapping up the fabrication and install of the passenger side kidney piece, and rocker panel patches.
I coated the inside with POR15 (thanks Zeke) and then finished it off with my signature pigeon poop welds. First I used my propane torch to burn off the lead filler and give me something solid to weld on. I made a couple of rust repair panels and was able to weld them on before grinding everything down and coating it with POR15. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk
Rennch on YouTube
If you prefer the video...
Rennch on YouTube
Today I tackled more chassis restoration, and I had to use a bottle jack to spread my rear frame rails! The full roll cage of this car had "compressed" the frame rails a few mm, and my replacement panel from Restoration Design was a good 1/2" off from being able to be installed.
This was the jack I eventually used, with a 2x4 against the opposite frame rail. ![]() I was able to use one of my regular floor jacks as a "proof of concept" and got the piece in for measurement. ![]() ![]() ![]() Quick test fit of the outer rear latch panel piece.
Rennch on YouTube
After welding it on and cleaning up the welds.
![]() ![]() ![]() ![]() ![]() Then sealed up with a bit of POR15 as a stage 1. ![]() ![]() ![]() Am excited to get that rear panel on so I can finally fit the quarters. If you want to see the video of this whole process, here it is:
Rennch on YouTube
I'm just about to fully weld up my quarter panels and rear latch panel. I am borrowing a stock set of right and left bumpers to help dial in my alignment, but I'm curious what the general procedure is for ensuring panel gaps, especially around the doors, are spot on.
Here's where I am at the mo: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() My plan is to use lead filler where the factory did, but I'm most concerned, like I said, about panel gaps. What are the techniques to dial in my door gaps correctly?
Rennch on YouTube
Just uploaded a video on my quarter panel install!
Registered Minimalist
Great job Michael. Your perseverance is paying off. It's starting to look like a car again.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
