Banned
84 911 AC erratic cooling
Hello everyone,,,
Our 1984 911 was converted to 134 about 4 years ago. Recently had leaks in the system fixed and it seems to be working 'most of the time.' Had the car out last weekend and the AC worked fine for 20 min then it felt like the cool english news capread air stopped. Maybe 20 min later the cool air came back on (blower and cool nobs on full the whole time). I'm not sire if it it just a loose connection somewhere or some other issue. Your guidance in getting to the source of this issue will be greatly appreciated. Last edited by Gabar; 08-27-2019 at 12:43 AM.. |
911 enthusiast
The on/off action will happen when the compressor freezes up. You can leave the fan knob on high and the thermostat knob down a few levels to see if this helps cycle it on and off more so it doesn’t run itself to death. The thermostat switches can fail, especially if the long tube part gets damaged. You can also make sure the system has a full refrigerant charge (this needs to be done annually with r-134a and the OEM hoses). The A/C system is a mess on these cars, but there’s no shortage of helpful advice on here to troubleshoot. |
NOT the compressor. Other than that your advice is right on.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Vintage Owner
I have the same issue with leaking 134a, but hope that swapping out to Kuehl’s barrier hoses will help keep the refrigerant in the system.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
A/c
Then let's see. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
what Gerry said.
freezing up. when mine would freeze up it would not thaw out unless I turned it off.
86 930 94kmiles [_ _] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ _] RUNNING: [__] NOT RUNNING:01 suburban 330K:: [_ _] RUNNING: [__] NOT RUNNING:RACE CAR:: sold Last edited by T77911S; 08-27-2019 at 07:59 AM.. |
A) Air stopped coming out of the AC vent above the radio? B) Air was coming out of the vent, however it was not as cold as before? Thank you
Kuehl 1987 911 cab, modified https://griffiths.com/ |
Usually the evaporator freeze up is accompanied by a funky smell. Turn the temperature knob to full warm, and let it blow at max. In the heat, the ice will melt in short order.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Let the op clarify the question.
