He shouldn't get pinged for duty. I think you can declare at least a $1000 AUD of value and you'll be fine. The shipping will probably be about $75 to $100 US each way. I wouldn't imagine anyone other than timmy2 doing that wiring. Do yourself a favor and just have timmy2 do you a section of harness at a time. The savings in grief will be worth the investment alone.
Sent from my Pixel 2 using Tapatalk |
I have to mention that most things that I have tinkered with in the car so far seem to work just fine. There are some dash lights that don't work which I suspect may also have something to do with the side mirrors not being connected and other bits not connected up just yet. If I can get every thing working for the time being, then that will be fine. I can look at re wiring once the Porsche fund has been topped up and the car is running. I pulled out all of the horrible plastic wire wrap that was in the car. Such an improvement already. Hahaha ![]() I rebuilt an engine with no experience, rebuilt a transmission with no experience (but some help from a pro), im sure I can have a go at this and learn a lot in the process. Now, back to my newbie questions. What harness wrap is best to neaten this mess up? Sent from my Pixel 2 using Tapatalk Last edited by Adrock; 10-09-2019 at 05:26 PM.. |
I would recommend as you trace them, you label them with the starting and ending points for future reference. Some thing like: Fuse 6 to Left Headlight; or F6 to L1 (using the codes from the wiring diagram) A quick look at Amazon shows several options. In my opinion, The tapes and braids look the most professional. The spiral wrap and split tubing is easy to use. Tie wraps are effective and easy but, at times, can look amateurish. In the end, I would defer to Dennis on this topic.
El Duderino
I’ve been using techflex on wiring. Another idea is to use color coded heat shrink. You can get clear for protecting labels.
I’d suggest labeling your wiring with the naming convention used on the factory diagrams even if you don’t have the proper colors so you can match them up easier and avoid confusing yourself down the road when you forgot what this or that meant.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
ROW '78 911 Targa
Use anything suggested for wrapping up the mess.
Labels are very important. Looking at the recent photo makes the original split loom look good!
Thought I'd try something easy and work out why the front right indicator wasn't working. Opened it up and found this. Lots of white oxidation or corrosion (?) I assume. It's rock hard and super hard to remove. Its all over the housing and connections. The globe was cemented in with this stuff. I had to smash it and pull it out with pliers. I cleaned it up and managed to get it working again but it's a bit hit and miss. Needs a proper clean. Wire brush on drill didn't work too well. ![]() ![]() ![]() ![]() ![]() Sent from my Pixel 2 using Tapatalk |
El Duderino
Is it possible the car came from someplace where they use road salt in the winter?
IMO; Calcium Carbonate deposits from being by the ocean
soak in vinegar, clean with wire brush
1980 911 - Metzger 3.6L 2016 Cayman S |
El Duderino
Huh. It looks odd. Only other thing I can think of is the kind of corrosion that comes from exposure to salt air.
Edit: Ted beat me to it.
Also in the ignition box.
Funny, because I'm yet to find a single piece of rust on the car. Maybe it went for a swim at some point? ![]() Sent from my Pixel 2 using Tapatalk |
Tsunami car?
Those low voltage circuit traces are the part most affected.
Next would be the termination points and the connectors. Would advise identifying each functional block of circuitry with its associated wiring and approach in that type of focused manner. The process of functional block elimination will allow the process to go faster after the first couple of hurdles. I did this on a 35 ft boat with lots of electronic and electrical stuff, a 14 ft car is possible also. Shout out to ORVAC electronics for parts support
On the weekend, I did a quick whip around the frunk and put yellow tape on all the unconnected wires and wires that were joined poorly and needed attention. There was a lot of yellow!
Also thought I'd have a go at installing the side mirrors. I took the switch apart and gave it a clean out. Connected all the wires up to their matching colours in the new harness and it works! The only thing I wasn't sure about was the two brown wires. Will need to research further. ![]() ![]() Also, does most of the wiring when complete, live behind the blower box? I assume I should be removing that so I can work on the wires behind it and then route them behind there once complete? Sent from my Pixel 2 using Tapatalk |
El Duderino
Yes, most of the wiring lives behind the blower box. I actually happen to have mine out right now so I’ll snap some pics for you later today.
Something else I wanted to ask everybody. What is the best option for crimping connectors? The last guy used the squeezy plier type and it looks super dodge and like they won't hold for very long. Any other options? Also, this little wire junction box thing seems a bit average and the copper wire seems a bit exposed for my liking. Any better options for those? ![]() ![]() ![]() Sent from my Pixel 2 using Tapatalk |
ROW '78 911 Targa
Non insulated butt splices installed with the correct compression crimper and heat shrink is best for the singles. Solder the ends or install ferrules (again with correct tool) on the terminal wire ends and trim to fit properly as Harry mentioned. The copper strands compressed alone will eventually fatigue, break and come loose from the terminal.
