Question Cat Delete. What do I need to adjust?
Hi All,
Car is a 78 911SC. All stock with exception of Danske Muffler. My Cat Converter has a small hole in it. I want to order a "test" pipe and delete the Cat Convertor. No emissions test since tags are classic car.
What would I need to adjust if anything on the CIS if I make the change?
Thank you in advance!!!!!
Old 10-02-2019, 12:45 PM
proporsche's Avatar
you do not have to do anything, just enjoy more horsies, about 5 i would imagine;-) and better sound
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 10-02-2019, 12:50 PM
New-ish 911SC Targa Owner
pampadori's Avatar
offset your carbon footprint by using less plastics. Forego the straw or the drink lid. Bring your own reusable shopping bags to the grocery store.
But I don't think your CIS is going to care too much.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Perfect, thank you for the feedback. Much appreciated!!!!
Old 10-03-2019, 05:21 AM
Crotchety Old Bastard
RarlyL8's Avatar
Be mindful of the final sound level that you are after. The bypass pipe is just that and can be a little loud if combined with a sport muffler. If so then a premuffler is a better option. Not all are created equally so take a look at the design and materials before you pull the trigger.
Old 10-03-2019, 10:53 AM
Make sure the bypass has an oxygen sensor hole, then you can run a wide band gauge. Best thing you can ever do for a CIS car. I like the AEM X-Series 30-0300 Wide Band, but that's just me.
Old 10-03-2019, 03:18 PM
Yep, check out the M&K pre-muffler instead of just a straight bypass pipe. Better sound, very nice quality materials and construction too.
Old 10-03-2019, 07:01 PM
New member to the 911 air-cooled world, but my first modification to this ‘76 coupe with 3.0 conversion was to drop the old restrictive exhaust and replace it with the Dansk st/st cat delete pipe and matching sport muffler. It has a healthy sound to it - no complaints - and the wifey even approved in her first ride in the car the other evening! Oh, and their matching hardware & gasket kits were excellent fit.
Old 10-03-2019, 10:03 PM
RarlyL8's Avatar
Could'a shed 20 pounds off that with an M&K, just sayin' ...
Old 10-04-2019, 06:39 AM
rnln's Avatar
guys,
I thought he would need to adjust air mixture?
Fat butt 911, 1987
Old 10-04-2019, 12:55 PM
May need to adjust the idle mix a bit richer now that the cat is gone. Who knows what it was set at previously. At least have it checked.
206 637 4071
Old 10-04-2019, 01:12 PM
Adjusting idle mix in SOP when deleting the CAT??
1987 3.2 Carrera Coupe - Venetian Blue
Instagram - roblkendrick
Old 10-04-2019, 05:08 PM
Banned but not out, yet..
RSBob's Avatar
I would recommend taking shallower breaths.
I was shocked at the increase in exhaust after I deleted my cat. Since it doesn’t get driven much I can rationalize not putting it back.
Old 10-04-2019, 07:27 PM
Thank you all for your input.
Old 11-18-2019, 12:54 PM
Dr J's Avatar
May get some popping and gurgling on hard decel (sudden closing of throttle when previously at high rpms) which many of us actually enjoy.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 11-18-2019, 02:21 PM
Still here
pmax's Avatar
You'll get more CO/NO/HC wafting into the cabin and more exhaust sound.
Not fun IMO in a targa...
Old 11-18-2019, 02:29 PM
I just got a test pipe for my 81 Targa. We'll see how it all goes this weekend!
Old 11-01-2023, 08:02 PM
M&K a nice, easy 20 lbs savings waaay in the rear...
Old 11-02-2023, 07:11 PM
PCA Member since 1988
If you still have the air injection pump and system, delete those while you have the exhaust apart.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 11-02-2023, 10:21 PM
Schulisco's Avatar
I would check the mixture if it's remained the same as before removing the catalyst. Without the old cermaic catalyst the exhausts flow faster and this could cause a leaner mixture. Best is to use a wide band oxygen gauge to monitor the mixture while driving to see if there are any faults.
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 11-03-2023, 01:27 AM
