Interior light not working, I need some help please.
I mean the two lights above the driver and the passenger in the headliner, these two lights were working OK but after I got the car back from the body shop they stopped working, I know the body shop has removed both doors off and I'm not sure if they let any wire disconnected, the problem is I have no idea where these wires would route. I removed both lights and I can see that the driver side has two single wires (brown and grey) and the passenger has two double wires of the same color, but I don't know where the wires go. The car is a 1976 911S.
Old 11-06-2019, 12:22 PM
Did you check the fuse? Also check the door jam switches. They may have broken the wires on them if they removed them.
Old 11-06-2019, 12:43 PM
Fuse is OK, I dont think its the door jam switch as they dont light at all in all three positions.
Old 11-06-2019, 01:38 PM
ROW '78 911 Targa
timmy2's Avatar
Passenger side in the trunk area above the glove box is where the wires connect. Also connects to trunk lamp there. Likely need to remove blower motor cover in the trunk to access them.
If glove box light works, there is power in the circuit.
Black and brown wires with male spades connect to the 2 wires going up in the left windshield frame.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-06-2019, 02:51 PM
On my 1985 911, the clock, glove box and trunk lights are all on the same circuit as the interior lights. If any of those others work, your fuse is ok.
There is a weird little white connector to the fuse that is easy to pull apart to kill those circuits for maintenance work if the doors or the trunk is open. See it yah is working.
I have a thread on the tech site with pictures and better description. Search for that.
Old 11-07-2019, 02:26 PM
ROW '78 911 Targa
timmy2's Avatar
That small connector doesn’t exist on a 76.
Directly wired to the fuse.
Dennis
Old 11-07-2019, 04:48 PM
carreradpt's Avatar
Are your lights 3 position types? on all the time, on with door open and just off?
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 11-07-2019, 06:09 PM
remove the rubber boots on the door switches and see if the lights come on, the boots get dried out and hold the switches in the "open" position not allowing the switch to turn the light on despite the door being open... some new boots will correct this as the rubber is nice and flexible
Old 11-08-2019, 04:55 AM
Send a message via ICQ to AirJose
...almost sure is the door switch. Happened to me! start by following ryans65 advise. The door post switches are around $7.50 a piece.
Jose
Old 11-08-2019, 05:34 AM
Had the same issue with my 1975 911S. Pulled the door switches, a spray with Deoxit and working perfectly. Contacts probably not seen the day of light in 45 years.
Old 11-10-2019, 08:29 AM
Banned
Unscrew the switches from the jamb and clean the female threaded area on the jamb.
They may have painted the threads and now the switches aren't grounding.
Old 11-10-2019, 08:52 AM
Careful, don't let the wire fall back into the door jamb hole. IIRC, there is not a lot of slack...
Old 11-10-2019, 09:49 AM
The 3 position on my glove box light not working properly.. problem position is the where the light should come on when the glove box door is opened and closed.
Old 06-01-2020, 06:41 PM
Depending on the year there is a wire to that glove box switch that often gets unknowingly pulled or snipped by people doing radio installs. Might check that first.
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 06-01-2020, 09:09 PM
