86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Intense window cleaner.
Trying to service/understand this system which is not
on the window sticker option list, and never used.
As per the attached pic of the my owner's manual,
it would appear that the intense washer should
activate the secondary washers & wipers by just
pressing the switch located under the gauges.
When I press the switch "nothing".
The pump works when voltage is applied at the pump.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 02-14-2019, 07:57 AM
I see the same thing. Maybe the intense fluid reservoir is clogged.
Old 02-14-2019, 08:35 AM
Washers.
Not clogged.
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-14-2019, 11:00 AM
Len 911's Avatar
I think you have to have the lights on for the switch to work..
Old 02-14-2019, 12:55 PM
Lights.
Correct, they were on.
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-14-2019, 12:56 PM
Maybe it's broken.
JUAN
'80SC Targa
Old 02-15-2019, 04:38 AM
It is a separate pump from the windshield pump. At least on my 85 it is. It is really hard to get to to replace. Up behind the bumper and washer bottle.
Old 02-15-2019, 07:31 AM
Pump.
The intensive washer pump is appended to the water
reservoir located near the driver's side front strut.
Easy access.
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-15-2019, 07:49 AM
So, this is a two step process.
1. Press the switch.
2. Then, turn on the wipers.
Right?
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-15-2019, 09:34 AM
Recreational User
porschenut's Avatar
Gerry, yes that's right.
Some of the posters apparently have mistaken the intensive washer system with the headlight washer system. Lights aren't required to be on to use the intensive system.
If the pump will activate when fed 12V directly, but not operate when the switch is pressed, then either the switch is faulty or there's an issue with the wiring.
Old 02-15-2019, 08:05 PM
schoward's Avatar
I don't know this system, but the manual above describes a time limiting relay (guessing like a seat belt warning light timer). That relay check out? I would assume, like the seat belt light, if that relay is shot or missing, no go.
For the switch - I would think you could test to see if switch is bad by popping the clock out, pop the switch out from behind and direct connect/touch the wires..
Scott
1981 911SC Targa - Platinum Metallic
Old 02-16-2019, 07:50 AM
pavegeno's Avatar
Send a message via Skype™ to pavegeno
My car came with the option but the plumbing had been removed by a previous owner. I restored mine last year. Just used the PET guide to order the parts and reconstruct. New parts are available from Pelican/Suncoast. I ordered several bottles of fluid from my local dealer for about $10/bottle. Part number is 000-044-000-93. Works nicely. Be sure your reservoir cap has a good rubber seal. The fluid will evaporate from the reservoir over a day or two if you leave the cap off or have a dried out rubber seal. As mentioned, you don't need the lights to be on.
2002 GMC Yukon SLE - 4AT - Purchased New in 2002
1988 911 Cab - 5MT - Purchased Used in 2005
2008 Cayman - 5MT - Purchased New in 2007
2014 911/50 - #1173 - 7MT - Purchased CPO in 2014
2019 Macan S - 7PDK - Euro Delivery/New in July 2019
Old 02-16-2019, 08:29 AM
pavegeno's Avatar
Old 02-16-2019, 08:37 AM
steely's Avatar
Hi Gerry,
Is this absent from your '86 schematic?
I do not have the option in the car, but it is shown on my '87 vintage factory schematic. (Zn A15 to C16)
There is a power tie between the relay and the wiper motor slip-ring, but I am not sure who is powering whom.
The relay is more like a solid state Porsche controller, where the logic isn't readily apparent to me.
pls let me know if you need a copy.
Dan
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 02-16-2019, 11:01 AM
Intensive windshield washer-How it works.
The 12V for both windshield washer system pumps is provided by fuse #3 block #1.
The normal windshield washer relay also has a 12V source from fuse #7 block #2.
This source is only for the active/timing circuits, and not the pumps.
When the Intense windshield washer system switch is pressed, 12V
is passed onto the relay circuitry which closes the relay putting 12V on the pump.
So, basically each system requires a low current (for the relay circuits),
and, a high current for the pumps.
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-16-2019, 12:49 PM
Window sticker.
Also, is there any indication of the "Intense" window washer
on our window sticker?
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-16-2019, 01:07 PM
steely's Avatar
Any idea as to why the same power is fed to the intermittent "action control"?
I see your diode is common to this line as well.
Dan
Venetian Blue
Old 02-16-2019, 05:23 PM
steely's Avatar
Gerry
Not even on the options sticker?
Dan
Venetian Blue
Old 02-16-2019, 05:24 PM
Power.
When I have time, Ill go through the circuit.
not sure why they did that.
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-16-2019, 08:31 PM
Links.
As a modest "Thanks" to those who contributed to this thread,
here are two interesting threads.
https://www.youtube.com/watch?v=e2RqkUE5Grw
https://www.youtube.com/watch?v=-lEsj19bdyM
Please share.
Best,
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-16-2019, 08:42 PM
