				Caliper piston persuader
			Thought that I better get busy and process my pile of stuck calipers, especially two SC rears i want to use on my '69 project, which will save me about $400 over buying new ones.  I ordered this bug master cylinder and metal reservoir from CIP1 and whipped up this quickie setup to push out the frozen pistons. Works great. Shoulda made one years ago instead of fighting the damn things.
	https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071  |
			 AutoBahned
			'69 project ???
	is there a thread yet?  |
			Damn, should've brought my 3.2 calipers to you, John. Spent the better part of a weekend trying to get the frozen pistons unstuck from the 3 out of the 4 calipers.
	Paul 1987 Carrera coupe  |
			There are times when air pressure doesn't get it. Most times lately.
			I read somewhere using a grease gun also works well.  is that correct?  getting adapters may be a challenge?
	Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
			Great idea. Pressurized hydraulic fluid for this purpose is much safer than compressed air.
	1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!  |
I've used a grease gun for years . Just remove the bleeder and screw in a Grease Zerk [ nipple ] . I guess the only problem is grease in the caliper but you are taking it apart anyways .
			I think a different handle is in order. A downward pusher would be easier than pulling. An L shape. Some of these things were really stuck, but they moved a 1/4" with every pump. Don't see how a grease gun would have moved them.
			Clever gadget.  I used compressed air on mine, but you've got to be really careful to keep your fingers out of the way.
	'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
You're right John , I had one of my 69 ,many years ago , that was so corroded that by the time I got the piston out with a grease gun and a lot of heat ! I had to get the caliper bore sleaved and a new piston . Your rig looks very cool !
			That was just a rough quickie design to see how well it worked. I cleaned it up a bit today and made a long round, push down handle instead of the flat pull handle. Much more comfortable.
			That setup will leave lot less cleaning but grease gun without tip wil screw right to caliper, and that will drive any piston out regardless how stuck they are. So works very well if doing calipers occasionally, but your setup is quicker as its slow to clean grease from everywhere. I'm literally just now putting together 14 calipers (yellow zinc plated and all rebuild) and I needed grease gun for every single of them.
			Modified the thing a bit.
			Nice one John!
	Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.  |
			Looking good around there John.  How is the new location working out?
			 Troll Hunter
			Recently took 2 hours getting 4 frozen pistons out of the rear calipers on my 72. We C- clamped them back a little, applied air, got them to move a little, repeated the process etc over and over with liberal applications of PB Blaster. Those babies were IN THERE, but they finally came out with a loud POP!
			I damaged one of the pistons beforehand by man handling it with some vice grips. I received a new piston today, but it does not have the cir-clip and tube set up inside of it. How does one remove the old piston inside parts and reinstall them in the new one?
	1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS  |
			 AutoBahned
			pretty - but I bet you are not as close to a bewpub as you were...
