might have the record
...for largest A/C condenser mounted in a 911.
The PO of my '80 SC was apparently VERY into having good A/C here in Vegas. How much? Here was the auxiliary condenser mounted under the car (it was plumbed in in addition to the usual one up front): ![]() This goliath was mounted transversely under the front seat area. Its length is the width of the passenger compartment; it stands about chest high when stood on end. I wonder what it was originally built for. I bet he was cool and comfortable!
2018 911 Carrera coupe 1972 911T targa |
I nehver saw one but recall the conversation about the install and efficiency
Bruce |
I'm good with tools.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
Yup, here it is with the standard condenser sitting on top of it for perspective:
![]() I bet you could have used this 911 as a meat locker when all of this was operational...
So are you removing the AC system and you live in Vegas?
That is a big condenser. I have 4 condensers in my 85 911. The Griffiths system. It works very well.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Yes; I am taking the car much in the direction of Nux's cool stone grey targa project. A lot of unneeded items including the A/C are coming out as the early stages of a lightweighting effort, while I also re-do the EFI the PO installed. See my other thread on this.
I think that’s part of a system made by Performance Aire who were in Anaheim.
I have a complete system in my loft that I had on my RS 25 years ago. It was a bit of a problem with low suspension but got the temps down cold enough to see your breath in the car! It had to be taken off in the end as it would only work with R12 gas. Replaced with excellent Griffiths system. Nick |
Guest
Posts: n/a
You'd have a rolling meat locker with that thing.
Back in the day they were marketed as "Desert Duty."
Insert Tag Line HERE.....
My last project car that I bought had TWO of those mounted underneath!!! I do remember them being about waist high though, so maybe a foot shorter than yours, but TWO of them!! Those things weigh @ 50 lbs each also!
Marc |
I thought the Desert Duty condensers were just bigger front condensers - see:
Griffith's next generation front condenser is 75% thicker. I recall looking into these options in the 90s with my first 911, in which I was roasting in the summers back in humid NC. The whopping unit on my current project should be called Death Valley Duty.
