#147 of 2096
Installing a 915 on a 69’ 912
Hi,
Any tip / advice on how to install a 915 on a 1969my 912 ? Thanks in advance.
#147 of 2096 |
#147 of 2096
I need to know which pressure plate I have to use.
#147 of 2096 |
You have a push clutch, so the only 915 that will relate to that is a 76 912e one. May still have some t/o bearing interface issues, never tried it.
cycling has-been
Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
The 912e trans has a vw size mainshaft.
#147 of 2096
Hi again.
I explained to my customer all the pro’s and con’s for doing that and now we are back in the market for a 1969 5speed 901. Thanks.
#147 of 2096 |
I would rather be driving
There is a rebuilt 901/13 in the classifieds right now. Correct with 6:29 CWP.
Worth a look.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I believe I have a 69 912 transmission. I can check when I get back to the shop
gearhead
I’m going to assume the reason his client thinks he wants a 915 is they are adding power and need strength. The 6:29 (stock for a 69 912, but not stock for the 901/13) is weaker than the standard 7:31. Porsche used them for hill climbing and rally back in period and would toss them after one race weekend. I would be looking for just a plain stock 901/13 and then strengthen it with a new bearing plate and side cover.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Thread Tools | |
Rate This Thread | |
