what caliper is this?
Hello,
I have a 72 911 that is somewhat of a Frankenstein. The front wheels have been upgraded to 16 inch Fuchs because the suspension was upgraded such that it needs 16 inch wheels to fit the bottom of the shocks. I want to get new brake pads but unsure what ATE caliper this is from. The size of the caliper is 6 inches top to bottom. The size of the rotor is 11 inches vented. So is this original 72? or later like SC brake caliper?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
So do they both use the same pads?
All A's use the same size pads, but later ones have brake pad sensor provisions, On yours just ignore that, so yes get any pad for an SC or Carrera, any year from '76 up
I just measured and it is 24mm thick rotor. Would Ferodo pads be the grabby type? or something else ? Also, is there a bigger master cylinder that should go along with the bigger caliper? This 72 has no booster so not sure if the stock Carrera master cylinder would fit.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 Last edited by yelcab1; 02-06-2020 at 09:33 AM.. |
ATE # 3.2120 - 3901.3 But I haven't seen one in 30-40years You could fit an ATE ATE (ports face left) # 03-2123-3402.3 but it's a 23.8mm and makes the pedal effort go through the roof, some racers like it though because you get great modulation w/ it
I think I'll stick with the old MC. It is the pedal effort I'm trying to decrease, not increase.
