Engine serial number help / 3.1?
Just purchased a 79 ROW, highly optioned and came across a odd serial number and some weird parts I was not familiar with
Can anyone shed some light
Old 02-17-2020, 08:04 AM
Is it this??
https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1030224-remanufactured-911sc-3-1l-pistons-cylinders.html
Old 02-17-2020, 08:25 AM
No, I believe this is some sort of special model, SC-L or something, this is a two owner car with no known motor swaps in its history
Old 02-17-2020, 08:34 AM
I was thinking the factory option 3.1, not the conversion kit also discussed in the thread.
Old 02-17-2020, 08:48 AM
gearhead
You would really need the options list from the car to be sure. Hard to say just from the engine. It could be original or it could be a conversion.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 02-17-2020, 08:53 AM
There is a reference to the 3.1 engine number stamp in this article quoting Jim Williams
https://www.excellence-mag.com/issues/180/articles/point-one
Old 02-17-2020, 08:58 AM
al lkosmal's Avatar
It is not likely that the conversion, that was reportedly.....a dealer "secret" option, would be listed in the original options list. Based on the little research i've done....the cases were stamped with the 3.1...and the Turbo cylinders were used,,,these would be the external,visual clues that you have a 3.1...as mentioned in the Excellence article........
RGruppe #669
http://www.x-faktory.com/
Old 02-17-2020, 09:50 AM
It’s got the same *3.1* stamp shown on other 3.1L engines. Nice find!
_______________________________
1982 911 SC 240,000mi and counting
Old 02-17-2020, 09:53 AM
what am I looking for on the turbo cylinders? any clues?
Old 02-17-2020, 10:01 AM
Post a pic of the fuel distributor, it should have a Bosch part number and be different from other ROW 911’s too.
Old 02-17-2020, 10:03 AM
al lkosmal's Avatar
fins?
The turbo cylinders, reportedly used for the 3.0-3.1 were only partially finned vs. the fully finned 3.0 cylinders.
here's a pic of the turbo cylinders (found on a Pelican thread)
RGruppe #669
Old 02-17-2020, 10:30 AM
Look like turbo cylinders to me
Old 02-17-2020, 12:14 PM
al lkosmal's Avatar
Score!!! Looks like someone installed one of the aftermarket Stainless Steel airboxes too!
what is the hole we are looking through????
RGruppe #669
Old 02-17-2020, 12:19 PM
Some busted up heater block off
Old 02-17-2020, 01:13 PM
