Engine serial number help / 3.1?
Just purchased a 79 ROW, highly optioned and came across a odd serial number and some weird parts I was not familiar with
Can anyone shed some light ![]() ![]() |
I was thinking the factory option 3.1, not the conversion kit also discussed in the thread.
gearhead
You would really need the options list from the car to be sure. Hard to say just from the engine. It could be original or it could be a conversion.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
There is a reference to the 3.1 engine number stamp in this article quoting Jim Williams
https://www.excellence-mag.com/issues/180/articles/point-one |
It is not likely that the conversion, that was reportedly.....a dealer "secret" option, would be listed in the original options list. Based on the little research i've done....the cases were stamped with the 3.1...and the Turbo cylinders were used,,,these would be the external,visual clues that you have a 3.1...as mentioned in the Excellence article........
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
It’s got the same *3.1* stamp shown on other 3.1L engines. Nice find!
_______________________________ 1982 911 SC 240,000mi and counting |
Post a pic of the fuel distributor, it should have a Bosch part number and be different from other ROW 911’s too.
fins?
The turbo cylinders, reportedly used for the 3.0-3.1 were only partially finned vs. the fully finned 3.0 cylinders.
here's a pic of the turbo cylinders (found on a Pelican thread) ![]()
![]() ![]() Look like turbo cylinders to me |
Score!!! Looks like someone installed one of the aftermarket Stainless Steel airboxes too!
what is the hole we are looking through????
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ Last edited by al lkosmal; 02-17-2020 at 11:29 AM.. |
Some busted up heater block off
Thread Tools | |
Rate This Thread | |
