Spark Plug Question
Hello I know our manual says to change our spark plugs every 30,000 miles or every 2 years. New cars today can go 100,000 miles before they need new spark plugs. So the question is do we need to change them every 2 years? I'm asking because I haven't even put 10,000 miles on them. Can they last 3, 4 or 5 years if it takes us that long to put 30,000 miles on them? Thanks
Jerry Baer 87 Carrera Coupe |
Others will chime in with more info, but I think that really depends on how "clean" your engine is running. Today's cars are running near stoichiometric air/fuel ratios almost constantly - my old 911 with CIS sure isn't. I swapped plugs in November and was surprised how much better it ran (only 15k miles on those plugs, too).
i don't worry about a time frame.
as said. new cars burn more efficiently. also the plug type can help. but run copper plus in your car. nothing fancy
John W
In Wayne’s book he recommends every 15,000 miles. As stated above age doesn’t really matter.
Can you just give them a good cleaning and reinstall? Why replace if the electrodes are in good shape?
1966 912 to 2.7 Frankencar |
The gap changes as the electrode wears. I noticed the NGKspark plugs wear faster than Bosch, I check the gap at least when I do a valve adjustment.
My main concern with plugs staying in place for extended time, is the action between steel and Aluminum. So pull them, inspect and reuse them if thy pass, with a smidgen of Antisiez
Red Line Service
Stay away from anti-seize on spark plugs, we use a dab of wheel bearing grease. The metal, copper or aluminum, in the anti-seize can short out the spark plug. Also, use the lubricant sparingly.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
I believe anti-seize can only short out a spark plug if some is smeared on the porcelain. Shouldn't be a problem if the anti-seize paste is confined to a little bit on the threads. Also, I worry about grease carbonizing on the threads closest to the combustion chamber.
1990 964 Coupe 1986 Carrera 3.2 Targa |
I want to thank everyone for the replies.
Location: behind the redwood curtain, (humboldt county) california
Pulled spark threads on Datsun
Many moons ago I pulled some threads on a hot rod Datsun work truck and really don’t want to repeat with the 911.
Is there a high temp dielectric grease that might avoid this problem, while not interfering with the full grounding of the plug. chris |
Functionista
Yes, but Datsun cylinder heads were made of compressed cheese. Avoiding unnecessary goops where possible is good practice.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Just for the record, I have been putting anti-seiz on sparkplug threads for as long as I can remember, and I have had my shop for 48 years. Every customer car, my cars, my 2 track motors, and have never experienced an issue because of that. I mean very LITTLE is applied. I do know that chasing down a problem, the wrong suspect can be blamed. Most of us work in a bit of a bubble and don't have the resources to do repetitive tests and we frequently will have conflicting results from what seems to be someone else's identical process. Pelican has provided a forum to help expand the bubble and I am grateful for it.
