nene's Avatar
After Replacing DME Relay Troubles...
I just replaced my DME relay(with a solid state)after the 30 year one failed, and now my 86 Carerra feels like it is running on a few cylinders?
The car starts right up stays on, but shakes. No smell of strong fuel. Checked fuses and all appear intact.
**Just to clarify,
I was driving to work earlier last week when all of a sudden the engine died and had to pull off the side of the road. After arriving home, I dug for the URO
replacement relay which I had purchased a few years earlier.
Arriving at the scene where the car was at, I installed the relay and the car sounded like it was running on a few cylinder. At any rate, I drove it like that home
which was only a few miles.
I then placed an order for the SS relay and come to find out the car is acting the same with this relay.
Old 03-02-2020, 06:03 PM
Was just about to buy a solid state DME, will be watching this.
Old 03-02-2020, 06:36 PM
My car as acting funny 2 years ago (i assumed it was the URO parts relay).
I got a wittrin (solid state was out of stock at the time)...first one was dead on arrival...2nd one worked for 9 months and occasionally wouldn't start.
Got the solid state one in August and it's been going well so far.
1987 Porsche Carrera Coupe
Old 03-02-2020, 07:10 PM
High Life's Avatar
Throwing this out there.. maybe it wasn't the DME relay that caused it to die?
Or something else happened during the stall?
1981 911SC
Old 03-02-2020, 08:42 PM
nene's Avatar
I posted a pic of the relay on a different thread, but here it is!
Old 03-02-2020, 09:32 PM
What do the pins of the burned out relay look like -- overheated/dirty? Did you clean & inspect the mating connector sockets (say, use deoxit)? Also, you can find threads on PP on how to make temporary jumpers to test start and test run the motor -- to see if you got really unlucky with a DOA replacement rly. Guessing (but no information on this) some reportedly DOA relays may just be misdiagnosis of DOA when all that happens is multiple insertions in the sockets eventually clears contamination.
'76 2.7-->3.2
Old 03-02-2020, 09:59 PM
So you are saying that the new solid state relay makes the car run like it's on "a few cylinders", same as the one which burned out shown above (and in the other thread)? FWIW, I have been using the solid state relay (with pump prime) for at least 4 years, and my cars runs perfectly on it. As mentioned by High Life, perhaps there is something else going on. You should try the test Grant mentions above to be sure (jumper).
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 03-03-2020, 05:36 AM
I don't think a DME relay has an effect on how the car runs so much as does it run or no run. Passes a go signal to fuel and ignition. Other issues it sounds like and would look first at the ignition. Bob
Old 03-03-2020, 06:10 AM
I have used the solid state relay with fuel prime for many years, and zero issues. It is basically your fuel pump relay. When a regular DME relay starts to fail you can get intermittent running.
I suspect that with the burned circuits on your old relay it means something is wrong with the DME itself. Find a friend with a similar model car, and put your DME in his car. If the problem follows, that will tell you it is your DME.
Don't put a good DME in your car because if you have a bad power or ground it can hurt his good DME.
I really doubt you have any issue with the solid state relay. It is likely something else.
Old 03-03-2020, 06:46 AM
nene's Avatar
I opened up the DME last night and unfolded the circuit-board to look at any suspicious burn marks, but noticed nothing that stood out.
If anyone within my area is willing to help out with the DME swap for testing, I would greatly appreciate it.
Thanks to all that chimed in...
Old 03-03-2020, 07:42 AM
1988 M491
Have you checked the Cylinder Head Temp sensor?
Old 03-03-2020, 08:27 AM
nene's Avatar
I replaced it about 6 months ago. The car had been running fine until this happened.
Old 03-03-2020, 08:37 AM
acar24's Avatar
I don't think I have ever seen a circuit burn like that. Some thing is shorting. I would maybe start with the coil, given their failure rate anyway. posible the DME, or fuel pump. clean and check connections at fuse board and engine panel wires. Distributor caps and rotors go bad could be the running issue but wouldn't take out the relay. Good luck.
Old 03-03-2020, 05:41 PM
Diss Member
Quicksilver's Avatar
For troubleshooting the DME relay just use a jumper. It takes any variability out of testing.
https://forums.pelicanparts.com/porsche-911-technical-forum/665035-dme-relay-carry-spare-2.html#post6619164
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-03-2020, 08:26 PM
Basically suggesting you chase down potential collateral damage/failure from the original failure; work your way outward from the known failure. I'm thinking you now have an intermittent connection which opens only when the firing engine provides just enough vibration to move poor connections. Only going after the rly socket 1st because the original relay fried (probably a bad/fractured internal solder joint) and the connector is the next thing in line to be damaged by excessive heat before the hot relay failed open. Suggest you want to eliminate a fouled connector. Also, check connector sockets front and back to make sure sockets are still seated properly and leads connected after your removal of the original relay. Jumper diagnostics may help before you search for (and even potentially introduce) unrelated problems.
'76 2.7-->3.2
Old 03-03-2020, 09:11 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Maybe something as simple as another component that overloaded the first DME relay (killing it in the process) and is still faulty. The fuel pump drawing too much current comes to mind:
FYI, a burned trace is not a normal failure mode for these DME relays. They have gotten a bad reputation due to cold solder joints. In your case the burned trace is more indicative of excessive current draw that heated up the trace and eventually causes it to fail as can be seen in your image.
If the fuel pump is marginal because one of its bearing is on its way out maybe it draws excessive amounts of current that are still under the rating of the fuel pump fuse but enough to cause this type of damage. The next actions:
- test fuel pump current draw
- check static fuel pressure and fuel delivery rate (if that is off it explains your poor running)
Good luck,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 03-04-2020, 03:42 PM
nene's Avatar
Good luck,
Ingo
Would the (cracked) solder joint moving side to side be able to cause that kind of heat?
Old 03-04-2020, 04:18 PM
ischmitz's Avatar
Whenever I’ve seen burned traces they were caused by overload rather than cracked joints. So it’s highly unlikely.
The trace is slimmest in the center between the joints and that’s where the heat is the greatest. A cracked joint either welds shut due to heat or opens up completely to the point where it doesn’t conduct enough current to heat the gap.
In either case there it wouldn’t produce sufficient heat to burn the entire trace like in your image. This was prolonged exposure to over current.
Cheers,
Ingo
Old 03-04-2020, 05:22 PM
nene's Avatar
I fully opened up the DME to take a look at the other side, which I hadn't. I found these two pins that appear to be missing the solder on the tip. I used my phone to do a 360 around them and it does appear that they are missing solder and not a lighting illusion.
What do ya think?
Old 03-04-2020, 08:20 PM
nene's Avatar
In the top pic, the pin in question is in the middle and the bottom pic is to the left mid way.
Old 03-04-2020, 08:23 PM
