Certified Pre-Owned
BGCarrera32's Avatar
Question 3.2 L head/cylinder stud retorque (should I do this?)
The engine of my '84 is currently out of the car- did the clutch and a bunch of other stuff. Ran through the valve adjustment again, and while I was at it checked all the cylinder studs to make sure none were broken (which I didn't think any were anyway).
But, all I did was throw a socket wrench with the hex bit in there and give them a good tug. Do these studs stretch? Should I pull out the torque wrench and go for a value? I am *really* leery of snapping a stud...what can you tell me?
Thanks!
-BG
'84 Carrera Coupe
Old 04-09-2003, 06:44 AM
Senior Member
Jdub's Avatar
I'd let sleeping dogs lie. You don't want to bust any of those studs.
John
'78 Targa in Minerva Blue
Old 04-09-2003, 06:50 AM
Rick Lee's Avatar
While you're at it though, I would torque down the rocker shafts. That's pretty easy with the engine out.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 04-09-2003, 07:04 AM
I would torque the head nuts to specs, there are several ways but what i would do is just throw torque it to 27lbs-30lbs and if it clicks it is OK. It takes a lot more than 30lbs to stretch a stud, ask me how I know.
Also as Richard L said, torque the cam tower nuts and rocker shafts as well.
What I would not do is to loosen the nuts and retorque. I am not sure if that buys you anything at this stage.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-09-2003, 07:37 AM
Certified Pre-Owned
BTW, the engine I have has unknown miles if that influences your opinion any...probably in the 150,000 + range...
'84 Carrera Coupe
Old 04-09-2003, 07:40 AM
i would leave it alone.
206 637 4071
Old 04-09-2003, 07:50 AM
