you see Arthur...
tune up issue
Hey there,
trying to find things to do during isolation, also decided to replace my spark plugs, cap and rotor. Plugs gapped, installed no issue. New rotor easily installed, cap. Turns out new cap was bad, so put old rotor and cap back on firing order is correct, and added a little dielectric grease to the spark plug wires. Fire the car up and it pops and sputters and is not running well. It was running like a champ prior to this. I have checked and check the firing order, make sure all the plug wires are seated. can't figure out what the issue is. Any insight would be appreciated. BTW its an 82, 911 SC 3.0 thank you in advance
J 82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat 06 Cayenne S 00 ML 55 AMG Santa Cruz Bullit |
it is possible that one or two spark plugs have closed gap..double check that
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
you see Arthur...
can some lay out the correct firing order. I have the firing order sticker with the arrow pointing towards the fan? is that correct, that would mean that if you are looking at the back of the car, cylinders 1, 2,& 3 would be on the right hand side. from the back looking forward. Is that correct?
Any help is greatly appreciated. car runs, but not well thanks
How old are your wires? Maybe the internals broke either on the wire or at the boot when they were removed. Check the resistance on each wire or remove one wire at a time while it's running to see if a cylinder isn't getting spark.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Under the radar
you see Arthur...
thank you. That is what I thought. I ordered new plug wires and will start again once they arrive from our host
thanks,
Don't forget that the dist. turns counter clockwise.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Make sure your boots are seated correctly, they can be a little tricky.
I once cracked one of the resistors when pulling them off the spark plugs.
If you have a multimeter you can test the ohms from distributor cap to spark plug connection and check they are all more or less the same. |
I'm in the same boat and sinking fast. Cheers, Joe 87 Carrera |
Ha.... yeah. If it ain't broke, don't fix it
you see Arthur...
yep, should have just left it alone. Well it gives me something to do I guess
What kind of plugs did you use?
2000 Boxster S and 2016 Audi A6 |
you see Arthur...
I used NGK, same plugs I had in before
to be specific BPR7ES. 5534. Same plugs as previous
J 82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat 06 Cayenne S 00 ML 55 AMG Santa Cruz Bullit Last edited by jasonlee; 04-19-2020 at 07:43 AM.. Reason: more information |
Good on the plugs. Just checking. Could you have possibly knocked a vacuum line loose? If not, hopefully the new plug wires do the trick.
you see Arthur...
thank you to everyone offering their advice. Good news, plus, rotor cap replaced and brand new Clewett plug wires from our host. She runs like a champ again.
Super stoked. Now I need to find something else to do to stave off boredom. thanks,
Good for you. Those plug wires get kinda sketchy when they're constantly exposed to heat/vibration. I've ruined more than a couple wires by messing with them.
If you're looking for something to do, why don't you bleed the brakes... is always nice to see the dark, cloudy stuff being replaced by clear fresh fluid. Gravity feed for a one man job is easiest... just keep a good eye on the reservoir level.
