djcdmv's Avatar
Is a fuse "bus" the same as a jump wire?
So I'm having power window problems and determined that the rivet holding the bus of the first two fuses has come loose. Is a jump wire between fuse 1 and fuse 2 the same as the bus that is behind the fuse block? Thanks in advance!
Dave
Black 1985 911 Carrera M491
Old 04-20-2020, 08:09 AM
ROW '78 911 Targa
timmy2's Avatar
Yes, a jumper wire will fix the bad rivet problem.
Might want to look at the replacement ATO style fuse panels Pelican lists for the future.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-20-2020, 08:49 AM
Connecting Rail
You could also use a Connecting Rail 901-612-835-01. These were used by the factory to jump between two fuses.
Old 04-20-2020, 05:29 PM
