Determining wheel size
I have a set of 15" wheels on my 83' SC. I believe they are 7's & 8's. How can I confirm that I am correct on that assumption?
I'm good with tools.
Measure them.....
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
if they're fuchs, they should have Porsche part numbers (and size markings) on the insides of the spokes -- other wheels (even aftermarket) should have similar markings -- pull a front and rear wheel and look what they show from the inside
If they are Fuchs ![]() ![]() measure if not this is a 7 ![]() this is a 6 ![]() wheels are defined by the bead width not overall width ![]() If tires are mounted use rubber bands to hold 2 laths that rest on the wheel flanges, measure the distance between laths and then subtract the width of the 2 flanges, for Fuchs you would subtract .7, most modern wheels have .5" flanges so subtract 1", BBS is an exception subtract .8
