Send a message via ICQ to old_skul
Hot Lap Questions
Okay, I'm considering purchasing a Hot Lap reciever and display for my car to do some lap analysis at the different tracks. You can buy either the reciever and display alone, or you can get the whole package with the transmitter as well.
My question is: do the tracks, specifically Mid-Ohio, Putnam Park, and BeaverRun, already have Hot Lap transmitters at the track? Will I have to set up a transmitter?
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 04-10-2003, 06:28 AM
Blackdimonds's Avatar
Question
Most tracks don't supply (have set up) transmitters for hot lap. However, at most events, someone (driver) has one set up. I bought the system without the transmitter, but added a steering wheel switch. This way I can still use the system if a transmitter is not set up at the track. With the switch, you can also time sections of the track that you may have a question about.
Paul
1981 911SC/RS
2001 Audi A4 1.8T Quattro
Old 04-10-2003, 07:23 AM
RETIRED
Joe Bob's Avatar
Nope....but many have the SCCA transponder units. Whether they are turned on during open track events are a different matter.
The transmitter for the hot lap is relatively cheap, works off of a 12 volt battery and a tripod. Pretty idjut proof.
2012 ML350 3.0 Turbo Diesel
Old 04-10-2003, 07:29 AM
Platinum Member
dad911's Avatar
I have a Hot-lap setup, it's a PIA to use. Tracks do not set up transmitters, and PCA usually doesn't allow timing at driver's ed. I just bought data- logger DL-90 as discussed in this thread: Data Logger
More expensive, but IMO well worth it.
Old 04-10-2003, 08:41 AM
John Brandt's Avatar
Mark
For drivers Ed, that would be strongly frowned upon, and you will have serious insurance problerms if something goes wrong. Besides, isn't that what girlfriends are for?
Old 04-10-2003, 09:13 AM
Irrationally exuberant
ChrisBennet's Avatar
Here in the Northeast at least, someone always has a Hot Leap beacon set up. The Club has nothing to do with it but looks the other way if you want to time yourself.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-10-2003, 09:30 AM
gchappel's Avatar
I actually use both the DL-90 datalogger and a hotlap timer- for different things and often at different events.
The problem with the DL 90 is it does not give any data while you are in the car. If I do a 10 lap run, and then download the data from the datalogger, I often cannot remember which laps were clean, when I got bogged down in traffic, etc. I find the hotlap timer very useful while on the track- if I think a particular lap was good or bad- I know immediately.
The data logger is useful for events that don't allow timing- and gives much better post driving evaluation of timing than the hotlap timer can.
BTW- I bought the total hotlap system 1yr ago, and haven't used the transmitter yet- there are always a couple already set up at the track.
Gary
Paul, by the way- how did you set up the steering wheel switch with the hot lap system- that would be useful
thanks
Old 04-10-2003, 09:41 AM
A. I don't have a girlfriend.
B. Personally timing your laps, as opposed to competitive timing, isn't something I'd mention to an insurance company if there were an incident. Is it a timed event? No.
I don't know if there would be a transmitter at the event. Honestly, I just need to get some sort of feedback now as to how I'm doing around the course. I know my times are getting better - I saw a 5-second drop between 2001 and 2002 - and I'd like to start getting better feedback on what it is I'm doing out there.
Mark Szabo
Old 04-10-2003, 12:24 PM
Thumbs up
First thing I did on my Hotlap set up, was to use velcro to attach the display box it to the car. This way if someone has a problem with it at a DE (if I'm an instructor or not) then I can remove it at the track with no problem.
Second, I just drilled a hole in the right hand spoke of the steering wheel. I placed it so I can just lift my thumb up and hit it quickly. I even used it once last weekend at our local autocross. That as fun to see how close I could get to the offical timing. I got with in .450 sec.
Paul
1981 911SC/RS
Old 04-10-2003, 12:30 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
How about a DL-90 and a video camera? Then after the even you can corellate the two together? Granted it's not instant feedback but at least you know how you're doing week to week.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 04-10-2003, 12:42 PM
Navin Johnson
TimT's Avatar
One thing to think about when using a hot lap at a track, is that sometimes more than one transmitter is set up at the track. This leads to some funky lap times trying to track down the other transmiters and getting a bunch of people to agree to set up and use one transmitter in a pain.
'69 911 GT-5
'75 914 GT-3
and others
Old 04-10-2003, 01:37 PM
Plavan's Avatar
Just to help guys who search for "Hot lap". There is something better out there now. The Hot lap is an old toaster now. The Ultra-lap is the way to go.
Here is the link. it is WAYYYYYYYYYYYYYYY better than a hot lap timer. Now there is a different choice for a little less $$$$ that is smaller and does a TON more. It works great.
NOTE 10/28/04: I may be even more biased now since I now sell them I will be updating the website soon www.plavanracing.com
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 10-22-2004, 10:27 PM
Administrator
Jack Olsen's Avatar
No matter who makes the box, there's no substitute for lap-by-lap real time feedback.
I've never heard of insurance having an issue with individually-timed cars at an event. A competitive timed event (as in: timed by the event itself) is another issue.
Old 10-22-2004, 11:05 PM
