What is the normal temperature operating range?
My car seems to run just above the little square box towards the bottom of the gauge (red line in picture) but I was sitting in the Starbucks drive thru yesterday and I noticed it crept up to the mid way point almost directly straight out from the "temp" (green line in the picture). When should you start to worry about temperature?
Old 04-23-2020, 12:46 PM
Bill Verburg's Avatar
You have a style C gauge, the bottom of the red zone is 150C (302F) the top of the white box is 80C(176F), 300F is too hot, a good place to be is just above the white box
Bill Verburg
Old 04-23-2020, 12:57 PM
One of the first upgrades I did to my 85 911 was get a temp gauge with numbers on it. It was a easy swap and a new sender and done. It seems to be very accurate.
With my car, normal driving in 80 degrees and below air temp I run at 180 or so. On a really hot day and hard running it will get to 210 and I turn on the fan for the front oil cooler. Even in the worst heat it never gets about 220 unless I sit in traffic a long time and 250 is about peak. I have never sat at idle for longer than that.
Old 04-23-2020, 02:05 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Oil temp.
This also worked for me.
The front oil cooler factory fan thermostat
was replaced with one of these.
On temp=210F
Off temp=195F
Using the style A insert.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-23-2020, 02:43 PM
sugarwood's Avatar
When it gets to the red section?
1986 Bosch Icon Wipers coupe.
Old 05-08-2020, 07:06 AM
Before that if it is a regular thing. 250 is hot, and 300 is way too dang hot. At least for my engine.
Old 05-08-2020, 07:55 AM
All - the op has a 3.2 Carrera engine in an 83 sc, could a mismatch between temp sensor and temp gauge elevate his readings?
Old 05-08-2020, 08:09 AM
PRO Motorsports
Tyson Schmidt's Avatar
Not likely. Same sender for those years.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 05-10-2020, 04:34 PM
thx for confirmation
Old 05-10-2020, 04:50 PM
racer_X's Avatar
Check the oil lines in the passenger side wheel well, there is a thermostat there. If the return line is cold when it is reading high on the gauge, that may be an issue with it's operation.
If the gauge is reading high and both are hot, it may be an issue with your fan (if you have one) on the oil cooler in the front fender.
John
1977 911S
Old 05-13-2020, 06:59 AM
The SC did not have the radiator type of cooler with fan as I recall. The Carrera was the first year of the radiator type of cooler. And it was 86 I think when the fan was standard.
So to the OP, if you have the trombone type of cooler, replace it with a radiator type, and add a fan to boot. I can tell you that as low speeds it makes a big difference. One of my buddies has a 82 SC and he recently had the front cooler replaced. It made a big difference for him.
Old 05-13-2020, 07:29 AM
Reiver
Reiver's Avatar
^^^ what he said.
I've the Carrera rad unit in my '83 SC and stay about 190 ish unless Arizona hot (100's ambient) and will go up to 210-20.....I control the fan with a switch btw/no thermostat
De Oppresso Liber
Strength and Honor 5th Legion
Old 05-13-2020, 08:58 AM
