Vent window seal/ wind noise question
Hi guys
Trying to figure out wind noise problem Does Seal # 12 go on inside or outside of door And should there bee scellant / butil between the side window frame and the outside and inside of door like picture circled in red. Thanks
OCPO
https://youtu.be/V2mbNZ2uWGI
Not sure if this will help but it’s a good tutorial on the internal Mechnaicals on the door. You might want to mention you cars MFG year in you post.
2018 X5 86 911 Targa 3.2 80 Mercedes 450SL 2006 530xi BillyBoat/H&R's....gone |
ER... I've heard that the black plastic plugs that go in the door's front and rear need to be there or there's wind noise. I've not proven this true or false.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
I am pretty sure #12 goes on the outside but I will confirm when I see my car again.
'80 SC Targa Avondale, Chicago, IL |
On my 87 item 12 is on the outside of the door.
Here's the TSB on Wind Noise and use of the plugs. Quote:
