CIS operating pressure.
At what pressure does CIS work?
Fleabit peanut monkey
Until someone that knows something chimes in....
Fuel pump pressure around 100 psi Step down to system pressure in fuel distributor to 65-ish Injectors spray at system pressure Control pressure (20-40-ish psi range) regulates how much pressure the FD plunger fights back with against the air sensor.
1981 911SC Targa Last edited by Bob Kontak; 05-31-2020 at 06:07 AM.. |
Crotchety Old Bastard
Depends on the application, CIS covers a lot of models.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
So what would the highest pressure be? Bob has pressure at the fuel pump at 100PSI, anything operate higher? Looking to have fuel lines made and want to make sure the lines can handle the CIS pressure.
under pressure
![]() ![]() regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
I thought some of the Bosch CIS pumps would dead-head at ~8.5 bar but can't seem to find that reference.
Is Len (BoxsterGT) still making fuel lines? He's been a good resource in the past. |
pressure
I went back through my docs and found this, which show max pressure for.....what i have noted as the 979 pump. As you can see...at what appears to be no flow, the pressure is 11 bar. (154psi).
Yes, Len is making lines and I consulted him. I was prepared to pull the trigger on Lens lines until my neighbor offered to make lines for me. My neighbor is rebuilding a Triumph Mark6 that he bought in 1970 when he was over seas. He worked for Sunoco making high pressures lines for thirty years and is making his own brake and fuel lines from a copper/nickle alloy tubing. I read in a thread where Len stated stainless steel is the best material to use. I am trying to make sure the lines I purchase can handle the CIS pressure.
You are purchasing a brand new Genuine Bosch inline fuel pump. Bosch 0 580 254 979 Inline Fuel Pump Bosch 979 fuel pumps mount inline (out side of your gas tank), most commonly rear center under your car or truck. Each Bosch 0-580-254-979 fuel pump provides 165LPH of flow and operate at 72.5 PSI. Bosch 979 Fuel Pump Specs: Bosch Part Number: 0580254979 Minimum Current: 12 Volts Operating Pressure: 72.5 PSI (5 Bar) Minimum Flow @ Outlet: 43.5 GPH (165 LPH) Fuel Pump Location: In-Line Fuel Pump Connections: Inlet: M14 x 1.5 Outlet: M12 x 1.5 Electrical: Positive M5 / Negative M4 |
![]() I would go 300 psi minimum for new lines. Steel should be way more than that.
1981 911SC Targa |
