993 increase intake airflow
Found some info about 993 intake only being good to 215hp and 6500rpm. Some mention of 996 GT3 intake to get more air. What all is involved in this swap or is there a way to get more air through a 993 intake?
Under the radar
Not sure where you got that info since the '96 ROW 993 had 300 hp.
Maybe you meant 315hp?
A stock 964 is 250hp @6100 either an al or later a plastic intake a stock 993 nvr is 272hp @6100 plastic intake a stock 993 vam is 285hp @6100 a stock 993RS(also a vram) is 300hp@6500 vram al intake a stock 993 Cup which uses the nvr intake is 320hp 6500 We regularly see 300+ from modified 993 3.6 & 320+ from modified 3.8 all using stock injectors Which brings up the real limiting factor stock 3.6 used 1 of 2 different injectors 964 use 195 cc/min injectors 993 uses 235 cc/min injectors once you get to around 320hp you want 32 cc/min injectors because the stockers are running at 100% duty cycle Besides the injectors the rpm is the next obstacle, stock crank is only good to 7k max, after that you need a GT3 crank and oil pump
Sorry. Typo. I did mean 315hp. I am currently at the 320hp mark. Injectors are not running at 100% as steve wong leaned out the mixture above 4000 as it was running 11:1. In trying to figure out the route to get even 10% more power. I read all the time about people getting 400+ out of a 3.8. 350hp would be nice out of my 3.6
John Dougherty said he wouldn't recommend any hotter cam than the 993SS for street use. Guess I should have done more research. Even Steve Weiner told me my cams are done by 6000 rpm so there was no need for me to work on increasing the rev limit of the engine. What would be a good cam that can breath up to at least 6500rpm?
w/ hyd lifters RS cams w/ mechanical SS are the happiest cans you can use w/ a stock intake, enginemangement and bottom end, rpm limit is still high 6s maybe 7 if you at least upgrade the rod bolts
I wrote this (ulp!
![]() Camshaft Selection -- First Draft It might answer some of your questions.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 06-05-2020 at 01:33 PM.. Reason: Fix typos |
W/ CIS and Motronic fual management cam selection is limited to those w/ little or no overlap, the more overlap the more intense the intake manifold reversionary oscilations which upset those two types of fuel mangement, If you go to carbs or ITBs w/ some form of electronic management then the limiting factors become valve clearance and rpm restrictions
Thread Tools | |
Rate This Thread | |
