Location: behind the redwood curtain, (humboldt county) california
The kit looks like it will get the job done. Looking forward to the track results. Did stoptech give you any idea of the pad. Characteristics? Are there any pad options?
I see you have ducted air to the rotor. I just did that to my M braked, (broken :-) 74, but haven’t had a chance to track it yet. How effective was that on your car?
Are the screens for clag, or do you have some other duct plugging hazard??
Thanks,
Chris
Old 06-20-2020, 05:32 AM
VFR750's Avatar
There are many brands of pads available. Stoptech ships with their 309 sport compound. This is supposed to be light track use.
I just bought a set of hawk HT-10 pads. I’ll used those for the track in the next few days. I’ll keep the 309s for street.
You can also get Porsche pads in the 309 compound. I just installed them in the back
I really want to go to Pagid RSL-29 yellow pads. Right now I’d have to use a slightly larger height pad to fit (2555 size) verses 2205. It’s a $290 gamble, but I really like the Pagid 29s. Street and track = no pad swaps.
The ducting really helps and the screens are to stop big stuff going into the scoops.
Done
Old 06-20-2020, 05:55 AM
VFR750's Avatar
One significant point:
I am not expecting a deceleration benefit. This upgrade was more about heat rejection and how that affects pads life and hub temperatures.
What I hope will happen is I get faster recovery, and less change in pedal travel over the course of a session.
Less heat into the aluminum hubs as evidenced by grease weeping from the caps.
Longer pad life. Especially if I can get the Pagid 29s to fit. Watkins glen 2-day events really burn the pads down.
Old 06-20-2020, 06:14 AM
VFR750's Avatar
First impressions
Bedded brake pads and the feel and modulation is great. 309 compound seems good for the street.
OMG it is so easy to bleed the brakes with dual bleed ports!!!
None of the issues with the ATE caliper being spongy due to a trapped air bubble.
Firm pedal from the get go.
Old 06-20-2020, 08:13 AM
1988 Carrera
shadowjack1's Avatar
I looked at the stop tech web site. I could not fine front brakes. Do you have a part number?
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 06-22-2020, 06:13 AM
VFR750's Avatar
83.782.FT00.A1 is the kit I bought.
Finding the proper website seems harder than it should be.
Old 06-22-2020, 06:44 AM
1988 Carrera
88' Carrera
75' Targa gone
72'914 gone
72' 914 gone too
Old 06-22-2020, 06:56 AM
Bill Verburg's Avatar
Stop tech kit is 5 lbs lighter
Had to double-up the parts and level the scale to get repeatable measurements
I’d treat these numbers as relative and not dead-accurate.
SC system 39lbs
21 lbs - 20mm rotors
17 lbs- ATE M steel calipers
1 lb - pads
Stop tech level 2: 34 lbs
21 lbs - 28 mm rotors and hats
11 lbs - aluminum calipers and adapter brackets
2 lbs - pads
The assembled rotor uses both steel and aluminum efficiently verse the all steel 20mm rotors
Note the Carrera front brakes are even heavier with the wide-M calipers and 24mm rotors.
All aluminum calipers are significantly lighter than stock steel calipers.
Is that per side?
Bill Verburg
Old 06-22-2020, 08:58 AM
David 23's Avatar
I got my full ST level 2 system a year ago, and am very happy with it. While I don't still have the specific individual component weights, I recall my ST system averaged 6 lbs. per corner lighter than the stock 911SC system I replaced.
1979 911SC 3.2 SS Custom Backdate Hot Rod
1972 911T, 2.7RS Spec
Beck 904 Carrera GTS /3.6
2023. Macan
Previously owned several 911 models since 1975.
Old 06-22-2020, 09:45 AM
VFR750's Avatar
Total weight reduction was about 5 lbs to the SC.
About 8-9 lbs lighter compared to the wider Carrera rotors and wide-m calipers.
Old 06-22-2020, 01:48 PM
Flojo's Avatar
My stop tech L2 front brake kit just arrived.
so this kit is examplarily installed on a SC (1978-1980)
I understand:
- no change of master cylinder
- no change of front hubs
- no spacers/adaptation neede with 16 Fuchs
- you get the hats and rotors, mount them to the hub and install everything with the provided caliper adapter and brake line.
job done.
correct?
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 08-05-2020, 02:13 AM
Looks good.
Thinking on getting this kit. Should fit nice behind 17'' wheels.
Old 08-05-2020, 02:26 AM
Flojo's Avatar
cant find it. only 83.782.DT00.A1 (slotted) or A2 (drilled)
https://www.apcautotech.com/part-detail/83782dt00a2?year=1979&make=porsche&model=911
Old 08-05-2020, 02:47 AM
VFR750's Avatar
FT00 uses the larger st43 caliper without dust seals.
Yes the front brakes are 100% compatible with 911SC and 84-89 Carreras.
If you google the part number you get multiple companies selling them.
Old 08-05-2020, 03:58 AM
Bli8's Avatar
Yes an SC. I’m not worried about the small bias change. Tires, air pressure, camber, temperature all affect braking. 4% difference is not something I think is significant.
$1749. Some places have it for about the same.
Would you mind sharing a link to the vendor's site? If not kosher to post publicly, then please PM me.
Bruce - Socal
'76 912e (e for electric, thus not 912E) Emerald Green project car
'19 GT3 RS Lizard Green track car
'19 Carrera T Carrera White family car
Old 08-05-2020, 04:27 PM
Flojo's Avatar
what interests me the most are the hats and 28-282 rotors from this set.
they have the same SC/Carrera diameter (282) but provide more width with their 28mm.
SC has 20 and Carrera 24
these and the offset of the hats will fit my 964 C2 calipers on my SC.
But I'm having a hard time finding a StopTech partnumber.
help?
Old 08-06-2020, 01:44 AM
VFR750's Avatar
I just did a google search on “stoptech replacement rotor”
Got multiple hits. Your choice as to order from.
I will cost 2x(345+230) to but just hats and rotors without the full kit.
Old 08-06-2020, 03:24 AM
sugarwood's Avatar
Lime rock on 6/25
Thompson on 6/27
Should be a valid test.
And?
1986 Bosch Icon Wipers coupe.
Old 08-06-2020, 01:55 PM
Flojo's Avatar
I do find a lot of stuff, I tracked down the sets, got the numbers for "race" and street" even separated tha caliper colors, I got the rotors (drilled or slotted)...but e.g. I can't find the hats as single
Old 08-07-2020, 01:17 AM
Any more updates on the brakes?
81 SC 3.8 Conversion
2017 Macan S
INSTAGRAM @tail_spinz
Old 02-08-2021, 08:12 PM
