Engine noise 2.2 with Weber’s
I have recently developed an engine noise and can’t figure out where it’s coming from. The sound is more prominent on the right bank. Sound like rocker noise, but not sure. Need valve adjustment ?? Gets loud at times.
Any input would be much appreciated. Video link is listed below.
https://youtu.be/1wr4C_joDRY
Old 07-04-2020, 03:23 PM
Pete,
A valve adjustment is the firs thing I would do. Even if that is not what it is at least you have eliminated it. Although I do think that it is a loose valve. You should be go ... hopefully!
Best of luck,
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 07-04-2020, 04:01 PM
Bill Douglas's Avatar
Does sound like valves. But have you got under it and felt around the exhaust ports for a leakage. Header pipes maybe.
Old 07-04-2020, 09:36 PM
proporsche's Avatar
Is this sound there when cold...if not - valve loose, if yes broken valve spring.To find exactly which cylinder ,use long screwdriver one end to each cylinder and the other in your fist and year
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-04-2020, 10:45 PM
Thanks Guys! The sound is there when cold. I guess it’s the valve spring as Evan has stated. How do I chk this?
Old 07-04-2020, 11:56 PM
id911T's Avatar
Another possibility is the chain tensioner on that side. I had a chain tensioner start to let go and the safety collar made a similar tapping sound as it bumped the tensioner body at lower engine speeds.
Stephen
GruppeB #906
1970 911T
Old 07-05-2020, 07:58 AM
So i solved the noise on the right bank. it turned out to be the chain tensioner. Now I have a ticking sound on the left bank. No sound when cold, gets louder as the engine gets to operating temp after a short run.
I have checked the valve springs and they seem fine. Also checked the tensioner on that side and its seem solid. Any ideas?
Here's the video link: https://www.youtube.com/watch?v=Cx2wow7HBwo
Old 04-23-2021, 08:14 PM
Hello pelicans, Any input on this? Much appreciated!
Old 04-29-2021, 12:52 PM
