Block hole in Engine Tin for heat delete
What do I use to block off these holes where heat tube went threw tin?
More Likeable IRL
there is a piece that the hole does not exist, or I found a long tin piece that forgoes that smaller part all together for my spec car. very rare, but you never know what you might find in the classifieds with a WTB add.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Get a carrera right side, one piece, no hole.
Bruce |
More Likeable IRL
Find a tin (or aluminum) can of the right size, cut down, fasten in.
_______________________________ 1982 911 SC 240,000mi and counting |
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
More Likeable IRL
did you use both pieces or just the flat cap portion? I used the bottom of beer cans to block off the heater inlet tubes at the body on my racer. i was drinking rolling rocks at the time if i recall..... scroll though my build thread linked above for a number of mcgeiver type things that i thought i was clever with. shopvac attachment cowl to cabin intake, black & decker grinder sides for front rotor venting block off plates and the like.
I found the 2 short ones with no holes. Factory German from Eimalig
I'm looking for this heat block off plate for left drivers side in metal. Does anyone have one laying around?
Thread Tools | |
Rate This Thread | |
