El Duderino
And for context, here is how he rates wear protection.
The Wear Protection reference categories are: * Over 120,000 psi = FANTASTIC wear protection * 105,000 to 120,000 psi = INCREDIBLE wear protection * 90,000 to 105,000 psi = OUTSTANDING wear protection * 75,000 to 90,000 psi = GOOD wear protection * 60,000 to 75,000 psi = MODERATE wear protection * 50,000 to 60,000 psi = UNDESIRABLE LOW wear protection * Below 50,000 psi = CAUTION – EXTREMELY LOW wear protection The HIGHER the psi value, the BETTER the Wear Protection.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
No idea about moly vs. classic. But it’s not the same oil. I also thought the rat dudes testing methods were pretty discredited. Either way. A lot of people use the M1 here with a lot of success. I’ll stick with moly. In winter I’ll probably switch to their 10w40
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 |
El Duderino
It's hard to know what to believe sometimes. Marketing people have gotten really good a muddying the waters on just about any technical topic. Some people think Bob the oil guy is great and others think he's a Pennzoil shill. Anyone that says anything opens themselves up to criticism. Just read this board for 2 minutes. ![]() I ran M1 15W50 for a long time and that has all that has ever been used in the last 20 years or so. I just switched to VR1 20W50. Regardless of what you think of 540RAT, it would be nice to see other viable options in the marketplace. Who knows if the maker of anyone's favorite oil will suddenly decided it's not profitable enough or that some environmental regulation has raised the bar too high.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. Last edited by tirwin; 07-14-2020 at 09:10 AM.. |
Regarding 10w60 - no matter which brand - the technical data sheets show a huge viscosity at cold temps, --> even its a 10w oil.
Especialy when driving in NE winters or at cold temps outside I wouldn't choose a 10w60. At normal use/driving, means not on the track .... as long as the state of your engine is flawlessly and if you change your oil in the suggested intervals you can choose all dino oils from 5w40 over 15w40, 20w50 up to 10w60. Beside a good ZDDP value I would choose the one with the lowest viscosity at coldstart and enough viscosity when hot. So when cold, all importand parts in the engine get lubricated as fast as possible. Quote:
And .... if you choose Liqui Moly oils ... you should choose the much cheaper Meguin oils (not shure if available in the US) as its "exact" the same product but with a Liquiy Moly branding – as Meguin produces the oil range for LM cause ... Meguin is part of the LM company.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ Last edited by AndrewCologne; 07-16-2020 at 12:00 AM.. |
I find this oil report from Blackstone laboratories. If anyone want it to compare.
It's a report from an other thread but here you have the Valvoline VR1
conventional standard for ZDDP from back in the day are for Z & P ~1100 to 1300ppm That's for API oil circa 1993 and earlier, SG & previous
Thread Tools | |
Rate This Thread | |
