915 Trans Speedometer Sensor
My car is a 914 but since the engine and transmission are both from a 911 I figured I'd post my question here.
I'm having issues with my 915 transmission and need to pull it from the car. While unhooking things under there I was surprised to find this sensor on the passenger side (drivers in a 911). My case is a 915/63 but I believe this is the speedo sensor from the last generation of the 915 (915/73). My speedometer has never been hooked up because I believed I needed to mill out a spot on the case due to the pinion gear being flipped for a 914. But the sensor for my case is different and would be on the drivers side. Does anyone know if the sensor that is there will work of i trace the wires and hook it up or does it need to be moved due to the flipped gear also?
Old 07-13-2020, 06:37 AM
ASE Master Tech - 35 yrs
larrym's Avatar
your cross post was answered on 914World by Luca
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 07-13-2020, 04:06 PM
I believe that is a G50 sensor with that retainer.
Bruce
Old 07-14-2020, 04:06 AM
