1988 3.2 Unplug the O2 sensor?
Need some input -> Problem with 3.2 transplant going lean and misfiring after two min
1988 3.2, I have been following the above thread and I found a comment about disconnecting the O2 sensor because it makes the car run better. Is this true?
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 07-28-2020, 07:56 AM
Vulnerari Praesidio
NO! Especially if you have chipped the engine.
"Wisdom is knowing what to do next; virtue is doing it."
- David Starr Jordan
Old 07-28-2020, 08:27 AM
Everyone has their own opinion (especially if it is colored by experience). In the tuning and modifications I have done, getting input from people like Steve Wong, Todd Knighton, etc., the consensus from them was that, as long as the system (Motronic) is in good order, the narrow-band O2 sensor is good, AFR values are good, and there are no leaks, etc., it makes sense to leave it plugged in. This is how I am running now, and it is fine.
Of course, now I will probably go out to the garage, unplug it, and see if I notice a difference...
YMMV.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 07-28-2020, 08:32 AM
Analog Air Cooled
Hotshot's Avatar
After dealing with a high idle, SW chip, and a cat bypass.. I decided to unplug mine and its been great. Had it hooked up to the old shop C02 machine and with or with out was negligible. Smogs not an issue here but was just in spec. Ran smoother without. Decided to unplug it... RUNS AMAZING. So I'm leaving it out. ill pay for the .3L of fuel... 2500km like this and its great..
3.2 86 Targa
86 Targa
91 964
13 6 SPD Cayenne
Old 07-28-2020, 08:48 AM
proporsche's Avatar
always unplug...it... unless you need to go for an inspection where it is required...it is there for emission purposes .All 911 in Europe and the rest of the world do not use the oxy sensor at all...when i worked in CA for 25 years on 911 always unplug unless you went for smog test......
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-28-2020, 08:56 AM
My 1985 runs just great, with it plugged in. It starts stone cold or hot and idles just like it should. No hesitation and pulls strong to redline. I can't imagine how it could do better with the sensor unplugged. I suspect the garage would stink more with the rich mixture.
The good news, it is real easy to plug it back in so trying it does not hurt much.
Old 07-28-2020, 09:15 AM
Ivan
Good way to shorten the life of the CAT! The early 911 3.2 Euro didn't use a CAT.
Ask any qualified 911 tech in CA, they'll say leave the O2 sensor connected.
Dave
Old 07-28-2020, 09:38 AM
proporsche's Avatar
here you go ....most of the disconnected oxy sensor-you should know by now- is on 911 where the cat has been removed and replaced with straight pipe...dude;-))))))Most of the Euro do not have Cat, it was an option to get better insurance price..i had a feeling you are picking around the corner Loren;-)))))
...sure i go look for qualified 911 tech in California --you make me laugh----maybe Swiss Motors remember them???
Ivan
btw i have an early model of Euro 911 and it came with CAT...
Old 07-28-2020, 09:59 AM
BER BER is offline
BER's Avatar
Porsche Crest
This is like a discussion of which is the best oil for our 911’s....no clear cut consensus, but lots of opinions. 🙄
I have a euro pre-muffler (I.e. no cat) and a SW chip in my 84 911. I have run with the O2 sensor connected and disconnected. I really could not tell any difference. My suggestion is do which ever makes you happy.
BTW-JG Driven GP-1 20w50. 😉
Bruce
'12 Carrera S DFI
'84 911 Carrera
Old 07-29-2020, 05:52 AM
Slippery Slope Victim
NY65912's Avatar
I have a euro pre-muffler and a Steve Wong chip in my 85 911. I run with the O2 sensor connected.
No issues, especially after refurbishing the entire intake system a few years ago including sending out the AFM and having the injectors rebuilt. No raw fuel order any longer.
Mike²
1985 M491
Old 07-29-2020, 06:43 AM
I believe the owner Of this site says it is important to leave it plugged in. Porsche says to leave it plugged in. My high end Porsche shop says leave it plugged in. My 85 Carrera runs perfect, I’ll leave it plugged in.
Old 07-29-2020, 08:00 AM
proporsche's Avatar
as i have mentioned it is for emission purpose..only USA models(mainly CA) have it in almost all 911. Europe and the rest of the world nobody really uses the oxy sensor and cats;-)
Ivan
Old 07-29-2020, 10:09 AM
Red Line Service
Marc Bixen's Avatar
Like he says, lots of opinions.
Red Line Service says..................LEAVE IT PLUGGED IN!
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 07-29-2020, 10:14 AM
proporsche's Avatar
Marc..that is for USA models ....others do not even have it in the system;-) correct;-))
Ivan
Old 07-29-2020, 10:46 AM
Red Line Service
Marc Bixen's Avatar
Ivan, play games with Dave, not me. If the car has the system, if Porsche and Bosch and their thousands of engineers, spending millions on component development, say it is right for the car, who are we to question it? You're talking like these guys who develop performance chips, yea they may get you more power, raise the red line to an unacceptable level, or advance the timing to an unsafe level, but in the end, they can't develop a better all around chip, that brings into account all the possibilities . It may diminish fuel economy, engine and or component life etc. If you want the lowest maintenance costs, the most diverse drivability, stick with stock.
That's all I've got on the subject. NEXT THREAD!
Old 07-29-2020, 01:00 PM
70SWT's Avatar
A 3.2 I had would run way too rich without the O2 sensor installed.
2018 911 Carrera coupe
1972 911T targa
Old 07-29-2020, 01:15 PM
proporsche's Avatar
Marc..no games unintended ,dude..just wanted to mention that the market made the catalyst for US mainly, for the rest of the world they do not use catalytic converter and oxygen sensor it their models..
Ivan
peace;-)
Old 07-29-2020, 01:39 PM
In Australia (Porsche Code C23) we had catalytic convertors on 911's from 1986 onwards. I think the same is true for cars delivered new to Japan and Switzerland.
But I agree that a well tuned 3.2 with idle mixture set correctly will show little difference with the O2 sensor connected or not. I know with my car I have monitored AFR with and without the O2 sensor and it only has an effect at gentle highway cruising and some minor effects at idle.
With my Australian delivered car I have a sports cat fitted and the O2 sensor connected and it idles and runs beautifully.
Davin
'87 Carrera 3.2
'66 VW Camper
'59 VW Beetle
Old 07-30-2020, 01:14 AM
proporsche's Avatar
thanx good to know;-)
Ivan
Old 07-30-2020, 01:40 AM
Porsche 935's Avatar
I deleleted my O2. Set mixtures and idle to spec and runs perfect without worrying it might fail in the future. On 84 Carrera, one less thing to worry about.
3.3 ltr, stock compression, efi, twin turbo - no intercooler.
Old 07-30-2020, 06:45 AM
