T77911S's Avatar
engine rebuild problem
putting my 930 engine back together.
had the heads rebuilt and ported.
was just curious so I did a leak down on the left side.
LOTS of air leaking past the valves!!!
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-09-2020, 07:39 AM
New-ish 911SC Targa Owner
pampadori's Avatar
I think valves leak until they pound their way i to the seats. I've read a handful of threads like this and that seemed to be mentioned in most.
What'd the machine shop that performed the work say about it?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 08-09-2020, 07:49 AM
T77911S's Avatar
haven't talked to hm. cant until next week
RACE CAR:: sold
Old 08-09-2020, 08:06 AM
I think you have to run it first before any leakdown test is valid.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-09-2020, 08:22 AM
proporsche's Avatar
+3 above... first drive then if problems occurs , leak down test..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 08-09-2020, 08:25 AM
Rebuilt heads.......
Ty,
A properly rebuilt heads should pass the liquid tests. If you put liquid like water or alcohol over the dome, there should not be any seepage of fluid during the test. If you do, it is not sealing well. This is a basic test before assembly.
Tony
Old 08-09-2020, 09:07 AM
Discseven's Avatar
Valve assemblies machined to spec do not leak when assembled.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 08-09-2020, 09:18 AM
Stranger on the Internet
patkeefe's Avatar
There should not be leakage from the combustion chamber to the ports, unless there is something physically holding the valve off the seat. They do not need to be run to seat properly.
Patrick E. Keefe
78 SC
Old 08-09-2020, 10:24 AM
proporsche's Avatar
do we know for sure it is past the valves....? as t77 told me he has the rockers off so above boys are correct no leak -
Ivan
T77..can do it again with a video so we can see it -the leak..
Old 08-09-2020, 11:28 AM
Are you certain the valves are properly adjusted and that you were on the back side of the cam for the cylinder being tested? The valves should not leak on a newly rebuilt head.
Old 08-09-2020, 11:32 AM
proporsche's Avatar
red..... i just wrote he has no rocker in ..yet;-)
Ivan
Old 08-09-2020, 11:36 AM
T77911S's Avatar
I have tape on the intake ports, its about to blow the tape off.
RACE CAR:: sold
Old 08-09-2020, 12:41 PM
proporsche's Avatar
ok take it of the engine set on the table pour some gas into the each chamber and see where does it leak -is the best you can do now...does not take much time to take it off..It is strange that machine shop would give heads like this??
Ivan
Old 08-09-2020, 01:04 PM
valve leakage
I always lap the valves in my self and use Prussion Blue then set valve spring height and reassemble.Do it once and do it right.Then you know.Ciao Fred
Old 08-09-2020, 01:37 PM
proporsche's Avatar
good point Fred ..but some of the peeps do not have the tool to do that ,that is why they trust the machine shops to do the job...
Ivan
Old 08-09-2020, 01:50 PM
T77911S's Avatar
I reputable guy on here did the heads.
I don't want to say who just in case there really is not an issue
definitely leaking past intake on 1 and 3.
2 was not as bad.
I have just done cam timing, no other rockers installed
RACE CAR:: sold
Old 08-09-2020, 05:14 PM
T77911S's Avatar
ok
just checked again.
its late and had shower so didn't want to stat out there and get sweaty
1 is better. le3aking past rings. I was a bit surprised since they were soaked in oil
3 is still bad. lots blowing out intake port. so I put a rocker on and spun it over a few times but it was still bad.
checked 4, it was tight as a drum
RACE CAR:: sold
Old 08-09-2020, 05:40 PM
Customer Service......
Ty,
Unless you got the job for a bargain, just be thankful. Otherwise, contact the rebuilder and give him an opportunity to fix the problem. Everybody makes mistakes, so allow him to address it. The integrity of your chosen rebuilder will be confirmed by how he handles a situation like this one.
You made a decision by not naming him at the moment. Keep us posted.
Tony
Old 08-09-2020, 05:58 PM
T77911S's Avatar
#1 stopped leaking
3 and 6 are leaking.
RACE CAR:: sold
Old 08-10-2020, 12:14 PM
T77911S's Avatar
I guess its back to working on the race car until I get this worked out.
RACE CAR:: sold
Old 08-10-2020, 12:15 PM
