AutoBahned
Big Sockets
i.e. sockets larger than 19mm for use on the 911...
One covid project is to re-organize the tool boxes, and I found a rail with a bunch of big sockets on it, so... I'll start: 20mm was needed to pull the nut on the wiper motor (not sure why they couldn't use a 19mm or go up to the next DIN spec. size) 22mm - not sure why I have this one actually... Last edited by RWebb; 09-06-2020 at 09:11 PM.. |
I believe the nut on the fan is 22mm.
I have up to 36mm in my tool box (not all for the 911...). |
I think the fan nut is 24 mm and the steering wheel nut is 27 mm if memory serves.
Rutager West 1977 911S Targa Chocolate Brown |
Covid project Really? Well you're in Oregon.
Being in Oregon...is that what makes you collect big sockets? It must be as I've added couple 1/2 sockets in need of working on BMW and Toyota. Porsche is not complaining so no new tools other than I bought this to replace those on snap-on sockets:
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
M14 is usually 22 mm. Bottom rear shock mount? A bunch of suspension bolts are 22 and 24 mm.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Just pick up a 3/4" drive metric set and a 3/4" torque wrench then you are never short. Big torque wrench makes installing the axle shafts easy.
Northern Motorhead
You might want some larger wrenches as well ... i believe the oil lines use 32 and 36 mm wrenches.
The biggest socket you need is for the axle !
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
AutoBahned
Let's save wrenches for the "Big Wrench" thread
32mm - must be for when I was swapping the rear spring plates (??) |
46mm for the big cam nut?
FWIW, Alternator nuts are 22 mm (early) and 24 mm (late). Steering Wheel is 27 mm.
Wildman Emeritus
Amazing how these sockets accumulate over time and projects. Lots of tools in all of our boxes used only on our cars. Maybe a separate tool box for the big fastener tools which will provide more space for additional 10mm sockets and wrenches.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
AutoBahned
AutoBahned
36mm is the largest socket I have - has to be from the rear suspension replacement but I forget which nut
springplate? |
I work on Ferraris and Porsches and have accumulated way too many big sockets and wrenches. Way bigger than 36mm.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Someone should start shop/tool box thread with lots of photos!
There is a large socket needed for the rear axle nut as well. I bought one in a 3/4 drive for my 3 foot long breaker bar. Getting it off is easy. Getting it torqued to the crazy high pound foot torque setting (325 comes to mind but I would not bet on my memory alone) is the hard part. I took my socket to a truck stop, and found a mechanic to come out with his 3 foot torque wrench. $20 bucks and two click clicks and they were torqued.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I found a 700 ft lb torque wrench on eBay for a song, so now I can torque the crazy Porsche axle nut.
