moparrob's Avatar
Looking for turbo part number or part
I can't seem to locate this part separately on any of the on-line parts schematics I have seen.
This is the drive pin for a 1993/1994 964 Turbo sump pump on a 3.6 liter engine. Just looking for the pin only, everything else looks good. Mine is showing wear and I would like to replace it while the engine is out.
Thanks in advance for any and all help.
Old 09-20-2020, 07:05 PM
Mic it. Maybe a drill bit shank is the same size.
206 637 4071
Old 09-20-2020, 09:14 PM
moparrob's Avatar
Not a bad idea. I wonder if the hardness and other properties of the drill shank would be suitable for the application though. I am not sure how much stress/load that pin receives.
Old 09-20-2020, 09:38 PM
It is hard. Takes a toll on the allen bolt heads. Maybe Brian @ rarelyl8 has one.
206 637 4071
Old 09-20-2020, 09:40 PM
You may also want to consider a standard dowel pin for this.
McMaster-Carr has a good selection of Dowel Pins but other vendors should also have a good selection.
Old 09-21-2020, 07:28 AM
moparrob's Avatar
Good tip, thank you.
Old 09-21-2020, 07:56 AM
