markmalin's Avatar
How do I remove the rear lower fender support?
I want to remove these so I can clean the surface rust off of them - long story.
How do these things come out, do they unscrew? Any advice would be appreciated.
Mark
Mark - New Glarus, WI
Old 10-01-2020, 01:26 PM
I would rather be driving
jpnovak's Avatar
Unscrew bolt in bottom. Then look in engine bay. Will be nut holding on the top. Have to flatten safety washer to get a wrench/socket on it. Not much access if you still have engine bay assembled.
Old 10-01-2020, 01:29 PM
Unscrew bottom to release from the fender and then loosen the nut (mine had a folded washer on the support rail in the engine bay). I then unscrewed the bracket whilst holding the nut/washer. Rubber grommets were perished on mine so check and replace. Cleaned up nicely with a quick blast.
Sent from my SM-G955F using Tapatalk
'77 911 Targa - currently in bare metal
Old 10-01-2020, 01:37 PM
markmalin's Avatar
Thanks guys. Looks like it may not be that easy with the engine in place, but I'll see if I can get at it.
Mark
Old 10-01-2020, 01:46 PM
You're welcome. This was my first ever "help someone else" post. I've been very lucky to be able to read and learn how to do so so much on my first ever Porsche project from a huge range of people here. It feels great to be able to give (even something small like this) back. This forum is amazing and has reduced my blood pressure to safe levels on countless occasions!
Old 10-01-2020, 01:51 PM
markmalin's Avatar
Seriously, the pictures and all were SUPER helpful. Thanks.
You must have had the engine out, right? Just curious.
Mark
Old 10-01-2020, 02:18 PM
Yes, engine was out. Definitely makes access easier!
Old 10-01-2020, 02:32 PM
I pulled mine with engine in, no sweat.
Old 10-02-2020, 06:49 AM
markmalin's Avatar
Thanks! Any tips or tricks on how you reached the nut/washer?
Mark
Old 10-02-2020, 08:09 AM
Once you remove the bottom bolt to the fender extension you can spin the rod to loosen the top nut and mine then unscrewed with finger pressure. Never messed with the bent washer, leave it alone. Tightened the same way.
Old 10-05-2020, 04:44 PM
markmalin's Avatar
Thanks!!
Mark
Old 10-05-2020, 05:12 PM
How much do these weigh? I was thinking making them in aluminum might be beneficial since they seem like way overkill for what they do
Old 10-05-2020, 05:56 PM
I'm good with tools.
AG81's Avatar
Me too !!!
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 10-06-2020, 04:15 AM
500g for the pair, I just weighed mine for you
Old 10-07-2020, 06:04 AM
Thanks thats not too bad . I dont know if its worth the trouble for me but perhaps someone else with better aluminum skills
Old 10-07-2020, 07:36 AM
markmalin's Avatar
Can you buy the rubber grommet on those as a separate piece?
Old 10-07-2020, 08:10 AM
AG81's Avatar
I did not look into that.....I made my own from some large rubber washers I had laying around.
02 996 4S
Old 10-07-2020, 10:43 AM
