How do I remove the rear lower fender support?
I want to remove these so I can clean the surface rust off of them - long story.
How do these things come out, do they unscrew? Any advice would be appreciated. Thanks Mark
Mark - New Glarus, WI |
I would rather be driving
Unscrew bolt in bottom. Then look in engine bay. Will be nut holding on the top. Have to flatten safety washer to get a wrench/socket on it. Not much access if you still have engine bay assembled.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Unscrew bottom to release from the fender and then loosen the nut (mine had a folded washer on the support rail in the engine bay). I then unscrewed the bracket whilst holding the nut/washer. Rubber grommets were perished on mine so check and replace. Cleaned up nicely with a quick blast.
![]() ![]() ![]() ![]() Sent from my SM-G955F using Tapatalk
'77 911 Targa - currently in bare metal Last edited by jaycee1977; 10-01-2020 at 01:40 PM.. |
Thanks guys. Looks like it may not be that easy with the engine in place, but I'll see if I can get at it.
Mark
You're welcome. This was my first ever "help someone else" post. I've been very lucky to be able to read and learn how to do so so much on my first ever Porsche project from a huge range of people here. It feels great to be able to give (even something small like this) back. This forum is amazing and has reduced my blood pressure to safe levels on countless occasions!
'77 911 Targa - currently in bare metal |
You must have had the engine out, right? Just curious. Mark
Yes, engine was out. Definitely makes access easier!
I pulled mine with engine in, no sweat.
Thanks! Any tips or tricks on how you reached the nut/washer?
Mark
Once you remove the bottom bolt to the fender extension you can spin the rod to loosen the top nut and mine then unscrewed with finger pressure. Never messed with the bent washer, leave it alone. Tightened the same way.
Mark
How much do these weigh? I was thinking making them in aluminum might be beneficial since they seem like way overkill for what they do
82 SC , 72 914 |
I'm good with tools.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
Thanks thats not too bad . I dont know if its worth the trouble for me but perhaps someone else with better aluminum skills
82 SC , 72 914 |
Can you buy the rubber grommet on those as a separate piece?
I did not look into that.....I made my own from some large rubber washers I had laying around.
