I use a product called DEoxit D100L 100% on all connections. I good preventive maintenance practice to clean all connectors and grounds. Now go get the CO set and you'll be set. Also, your residual pressure seemed low and dropped quicker that spec. You may have a little difficulty on warm starts. Keep us posted.
Dave K |
Took it for a test drive to Oakland and back to SF. Cold start appears improved and FV appears to be buzzing. However, backfire on highway presents itself upon coasting once in awhile (3x during the drive). After a stop in Oakland, the warm start issue presented itself. My impression is that mixture may be rich, and I may have a residual pressure issue at the regulator on the fuel distributor. Open to suggestions, and appreciate the help. Considering either finding a shop with the proper equipment to set mixture, or buying a CO meter to do so.
Mike 82 911SC Targa |
Don't do anything more until you set the CO. You should be able to find a local shop to set the CO or a local Pelican to help. This could cleanup the popping.
If it were me a would pull off the entire CIS system and replace all the gaskets and rubber parts. But thats me. The only true way to ensure no unmetered air. You can take the injectors to a diesel shop for testing too. You've done all the right things to this point. Enjoy.
Dave K |
Just another thought- you may have some leaking injectors too. Don't forget to check the cold start valve.
Dave K |
Thanks again for all your insight in this thread. After cleaning up the connector and test driving the car, the cold idle issue appears resolved. The backfire while driving around town was continuing, so I adjusted the mixture screw lean until the idle became irregular, and then went just slightly rich.
Took the car for a drive to a Porsche shop that was recommended, Pacific Motors here in SF. Had a 930 in the doorway and a bunch of long hood cars inside. The owner didn't seem super interested in talking to me about making an appointment and told me they are busy for the next two months and to check back another time. Popular guy, it seems! Drove over to The Smog Shop where I had my smog done & they had a Pagoda mercedes getting work done last time, so figured they'd be willing to do work on an older vehicle. Referred me to Metric Motors around the corner. Metric wrote the name of some "oldschool" guru and a number on a piece of paper and told me to call them. I was hoping to get a shop to set the mixture with a meter, but coming up empty so far. Willing to accept a recommendation if anyone knows a shop in/ around SF to dial in the mixture The car continues to run a bit hot around town according to the gauge, but no stall for the first time ever! I checked all the oil pipes with a temp gun and the t-stats appear open. 140-190* for all pipes, including t stat and trombone. 180*F at the intake runner, Sump plate/case tested at 300* F. I think I may have some remaining obstruction at the (leaking) engine oil cooler where I had vacuumed out a mouse nest. I'm sensing my next project will involve a drop or partial drop in my garage to do the cooler cleanup & seals and TOD. I'm a little worried about scope creep as I DIY, but I'm going to grab the 101 Projects book and make a plan to approach that session. Thanks again.
What plugs are you running?
Also, think about getting the O2 sensor connected and doing a more comprehensive smoke test. You still could have unmetered air causing lean running and high temps. Like i said you won't know until the mixture is set properly. Maybe a local Pelican can help with the mixture setting.
Dave K |
If you’re interested I can set your mixture for you through the test connection for the frequency valve. As long as your ECU, O2 sensor and FV Are working this is a very accurate method.
Wow, that'd be great! Yeah, these components are all either working or new. Are you based locally?
@Mike
Do you have a DMM which supports the reading of Duty Cycle? If not you should get one as its an essential tool for proper lambda based 911 engine maintenance. On the left side of the engine compartment theres a plug called test port. There you can connect your DMM to. But lets see first if 997at can assist you here on your site before going into a deep tutorial here.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ |
Watching from the sideline...........
Mike,
I’ve been watching this thread since the beginning. You mentioned that you did a smoke test. How did you do it? If you did not isolate the system properly from atmosphere, your smoke test won’t locate or find the hard to find air leak source/s. This is a very important and critical test. Not until you confirmed the absence of unmetered air going into the system, your CIS motor will not run well. You could tinker the fuel fixture setting to compensate for the unmetered air but this will not solve the problem. How many times have you adjusted the fuel mixture setting since you bought the car? Maybe you don’t have any air leak sources or unmetered air? But you don’t know that as a fact. And you are hoping there is none. You can not depend on luck all the time. Test and confirm. Stop guessing. You either have unmetered or don’t have any. Pick your choice. The other problem is your residual pressure loss. You could easily locate or identify the culprit/s by doing a fuel pressure test. This is widely discussed in the forum. Keep us posted. Tony Last edited by boyt911sc; 11-07-2020 at 01:54 PM.. |
CIS AFR at idle vs at WOT
Dave K |
As the cold start issue turned out to be electrical, my thoughts turned to this. I took the car out last night to have two tires mounted and have the alignment checked and spent a bit of time on the highway. Things I noticed about this "backfire": -The car will lose response and quit running as if randomly -After a second or three of trying to get the car restarted while coasting, will start with a backfire out the exhaust, Epiphany?: I realized that the quicker I performed the key off and on restart (within a couple seconds), the smaller the backfire. By this, I realized that I am likely dropping spark while the car is hot. Key back on restarts the ignition and BOOM ignites the extra gas in the cylinder. I will look to test the coil and cdi box for proper resistance values, before any adjustment is made to the mixture. I presume these values may be in the Bentley manual, but I will also continue reading and searching the forum. 997at, I will take you up on your offer, once I can confidently get on the highway again!
Mike 82 911SC Targa Last edited by mike621; 11-07-2020 at 09:31 AM.. |
I'd be happy to also take a look at your entire system and can help you troubleshoot and test. I have a smoke machine to repeat and confirm no leaks as well...it is critical that this test looks at the entire system and not just the air box. I also learned that spark is not always what it appears to be. After my complete CIS rebuild I could not get the car to fire. I visually checked for spark and it was there but perhaps not super strong. So I replaced the coil and it fired up before even the first full engine rotation. You really have to test each and every component to have another 20-30 years of trouble free running. As another aside, I replaced my blown air box and did not install a pop off valve in my new one...it is just one other item that can lead to air leaks down the road. If your CIS is tuned properly and you have a spider inlet (new) air box it is not necessary. Your CDI could also lead to some of the the issues you are having...mine started to crap out when I first got my car. I replaced it with an MSD ignition and coil...trouble free ever since. The journey can be frustrating...I can't tell you how many times I almost threw in the towel and considered getting rid of the car. Stick with it and once solved, these babies run beautifully and you won't have to worry for decades to come. Let me know how I can help. |
Tested the coil this morning and resistance values are out of spec between the small posts (.9). Appears original so I am going to swap in a MSD 8222 (avoiding all the Brazil coils out there after reading all the reviews) from our host and try a couple test runs on the highway before I attempt to make it to Orinda in the coming weeks Would welcome any retesting and thoughts from your experiences!
Update here. Installed the MSD HV 8222. Awaiting a non-rainy day to do some road testing to see if the warm stall has been mitigated.
Sunny day in SF today. Took the car out around town to run an errand. Super pleasant the first 20 mins. After the store, car was having hot start issue (I have low residual pressure at the CIS) Thinking a check valve for that is in my future. Wonder if I should do that on or off the car...
Though it's running a tiny bit cooler around town, still had the stall issue once, so my guess at the coil proved to be wrong. I'm still convinced the "stall" is spark related, as I cycled the key back to the run position and the car continued on after a backfire. Maybe its time to turn my attention to CDI box. After 20 mins or so of city driving, this thing is running at the upper white mark on my temp gauge, and still smoking a lot from oil leaks. I'm also feeling that it may be time before too long, for a partial or full drop to really dig into the demons.
I read through this thread 81 SC dying at speed for some inspiration. Going to take a look at the connection at the CDI & distributor. May dig further into the CDI depending on my appetite.
Did you ever set the CO to spec?
Did you test the throttle switch? Sorry I'm too lazy to re read the entire post.
Dave K |
