3.2 won’t start / power issue
Hi all,
My car has been sitting for 2-3 weeks in the garage while I was doing some work to it, but I used a tender in the past few days and the battery got fully charged. Unfortunately, my power windows, lights (dash and externals), and ignition are not working. I’ve checked the voltage at the battery and it looked good (12.7V), the current draw seems reasonable (12 mA), and I haven’t seen any blown fuse. Just to double-check, I removed the cruise control (servo, control unit and steering lever), but left the wiring harness in the car around the pedal cluster (as in it's no longer connected to the unit). I also removed the clutch switch, my assumption was that it's only required for the cruise control. Are those a potential source for my issue? Any leads I should explore? Thank you all for the help! Last edited by mziin; 11-03-2020 at 02:09 PM.. |
Call AAA. It's free if you're a member or if you know one. If they can't start it, nobody can.
jp..start with the basics.Do you have extra DME relay --alias fuel pump relay, it is under your driver seat.
It could be just coincidence that it does not start Do you have any alarm in your car system? Also the engine is turning over? If yes check if you have spark.. Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
No alarm. The engine is not turning over. |
How old is the battery? Pull it out, and take it to be load tested. The first thing to double check is always the battery. Batteries of today have thin plates and can short out, and show 12.8 volts, but have no amperage. Once you KNOW the battery is good, then start reading on the thousands of pages about no start on this site.
You can have a battery jumped with a known good battery, and it still not work because the battery is shorted. So don't assume since you jumped it and it still did not work the battery is OK. If the battery checks out, start with the grounds. From the battery connection to the transmission ground. Check them all, and clean them up.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! Last edited by GH85Carrera; 11-04-2020 at 09:43 AM.. |
ok i did not know it does not turn the engine.Does the starter click.Loosen the battery terminals and clean then make it tight.Also check your yellow wire on the starter if for some reason is off or loose
then report Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 11-04-2020 at 09:54 AM.. |
The battery is 2-3 years old. I took it for testing - and they deemed it was good... (somehow I would have hoped for a "not good", would have made things easier).
I also cleaned up the terminals and checked the starter wire, looks good to me but didn't solve my issue. Starter doesn't click. I know it's broad, and might not be related, but is there anything I should double-check as I was doing some work on the car? (related to cruise control servo/unit, clutch switch, steering wheel as I was removing the CC lever). |
We need specific details.
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
Hi,
the schematics are here for your model : http://911c1.de/porsche/Schaltplaene/plaene1-10_carrera_32.pdf See 'blatt 6' for the battery and the contact switch. The cruise control should not have an impact, you can drive the car without the unit in and the clutch switch is only used in the cruisecontrol circuit. You say some of the electrics (power window, ...) are not working, do some work then or are all dead ? Frank PS: on the right you find the cruise control (blatt 6), the area where you did the changes 'tempostat steuergeraet' = cruise control unit 'kupplungsschalter' = clutch switch 'schalter tempostat' = cruise control stalk 'relais tempostat' = cruise control relay
__________________ 1985 Carrera 3.2 Last edited by FrankM_; 11-04-2020 at 11:42 PM.. |
look under you dash on left ,if you by mistake disconnect the main plug from the ignition switch
Ivan you did not say are the lights on dash on at all?
Car is starting like normal... Thank you for all you help!! |
there you go..it was pain free ..glad to help;-)
Ivan
Go ahead and clean the transmission ground strap, a good clean ground is ALWAYS a good thing.
At least it was a cheap fix!
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Glen..i do not remember, does the g50 have also ground strap?
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 11-05-2020 at 10:46 AM.. |
Yes.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
cool thanx Lyle.......memory is failing me;-)
Ivan
It is impossible to have too many or to good of a ground. Anytime I am close to a ground, I check it just because it can't hurt. Weak grounds can make a great car act haunted.
