Trivial Question, 3.6 Turbo
What engine case does the 1994 Turbo 3.6 use? Same as the 3.3 or 964?
-Mark B. Hardware Store Engineer 1988 911 - 3.6 1999 SL500 - Gone 1995 M3 - LS2 - Gone 1993 RS America - Gone |
Neither it's unique
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
Crotchety Old Bastard
964C2T3.6 uses the 3.3L 930 engine with larger P/C to increase the displacement to 3.6L. Also uses the same CIS system which is last year for that as well.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Both the 964 3.3 and 3.6 have unique cases in addition to many other unique parts
The reason I know is I needed one of each
Is the 964 3.3 case different from 930 3.0/3.3 cases? If yes, how so if you don't mind sharing its differences.
MikeD '87 930 |
There are many unique parts but I don't believe the case is unique, other than the type number. It may have been modified to fit some accessories however the reason for using this engine was to reduce costs associated with adapting a turbo to the 964 engine and fuel injection system.
The case is definitely different then a 930/3.2 case internally and externally
In what way?
964 uses a crank sensor no provision for that on 930 case at the least
