ADDvanced's Avatar
Backdating Heat: How to seal up this engine tin?
So I picked up a set of 'heat backdate' engine tin for the shroud, but honestly, they both fit like crap.
There is a gap on the bottom edge, I can see the cylinder fins. There's another gap near the alternator/fan shroud. And there's a gap between the sheet metal edge and the shroud itself. Would foam tape work? Would it hold up to high temps?
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 11-15-2020, 06:00 PM
ADDvanced's Avatar
btw idk how the hell the driver's side is supposed to be compatible w carrera tensioners. I spent about 2.5 hours beating it with a hammer and tugging on it with pliers and using my vice/anvil to beat the metal so it doesn't just run right into the tensioner. It SORT of fits now.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 11-15-2020, 06:01 PM
MichaelSJackson's Avatar
Maybe photos would help us see what you're describing and/or a link to the vendor?
Old 11-15-2020, 11:39 PM
Registered Minimalist
75 911s's Avatar
The drivers side is difficult to fit. The tensioner must actually be removed to easily fit it in. I don't recall beating on it with a hammer, only that it actually isn't designed for a midyear case necessarily. On my 75, a small spacer was required to fit between the lower tab and the engine block boss, as the heat back-date piece would not sit flush there. On my kit, I believe both pieces came with adhesive foam to fit between the fan side and the back-date pieces.
Good luck.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-16-2020, 05:49 AM
ADDvanced's Avatar
Idk what else to say. It isn't fitting great, I'm looking for ideas on how to seal it up. Foam tape might work, I just don't know what heat rating it has....
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 11-16-2020, 07:58 AM
I had tons of problem with the heat backdate tin as well. The holes and shape just didn't quite line up. Lots of hammering and bending to get it on there correctly.
'66 912 - Polo Red;
'74 911s - Silver Carrera RS clone
'77 911s - Peru red IROC Clone
'89 964 C4 - Guards red
Old 11-16-2020, 08:08 AM
ADDvanced's Avatar
Yup. Problem is I had them powdercoated when the engine was apart.... so... trying to be gentle. I got them to fit 'okay', but there is still a gap, and there ALWAYS will be a gap on the bottom edge. Somebody has to have sealed this before, or know of a high temp weatherstripping.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 11-16-2020, 08:12 AM
plenty of options here: https://www.mcmaster.com/door-weatherstripping
Old 11-16-2020, 08:30 AM
Perpetual Reassembler
2jmotorsports's Avatar
I bought a set of aftermarket heat backdate tin and had the same situation. After a bunch of hammering and beating on them I gave up and sourced a set of OE ones on eBay and they fit perfect. The aftermarket ones went in the trash.
My driver side one still required a tiny bit of massaging to clear the 3.0L distributor, then I powdercoated them after verifying the fitment.
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 11-16-2020, 09:34 AM
wareaglescott's Avatar
Gold heat tape may do the trick.
Old 11-16-2020, 09:46 AM
With respect to high temp tape - I would google high temp tape there are several vendors out there that have some powerful stuff >> https://www.cabletiesandmore.com/thermashield-tape // I also backdated my heating tin on my 80 SC - don't recall any fitment issues..
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 11-17-2020, 08:03 AM
Ginger77's Avatar
Dang, that must be so disappointing. I've been eyeballing the QSC set for a while now. But a $140 for ill fitting tinware is hard to justify. Are there no better copies available?
Diederick
I drive a US import 1977 911. Formerly owned by a woman in California named Ginger - which appropriately led to the nickname.
IG: no dedicated account but photos are posted with #ginger77
Old 11-17-2020, 08:24 AM
I'm good with tools.
AG81's Avatar
I got mine at Patrick Motorsports and they fit great !!!
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 11-17-2020, 09:53 AM
ADDvanced's Avatar
I got the passenger side here on Pelican, and the hole was in the wrong spot for the shroud, and it isn't sealing along the bottom edge.
The driver's side panel I got from Allzim:
http://www.***********/store/911-heater-duct-backdate-kit-911-69-83.html
It was definitely this website but I only ordered the driver's side. I'll post a video in a bit on how much interference there is.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 11-17-2020, 11:18 AM
ADDvanced's Avatar
woah... weird. ALL. ZIM. DOT. COM. Weird that this website won't let me post a link....
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 11-17-2020, 11:19 AM
75 911s's Avatar
It's a competitor to our host. They don't want links to outside vendors.
Old 11-17-2020, 12:26 PM
They are competitors to this site.
Old 11-17-2020, 12:27 PM
Walt Fricke's Avatar
Pelican is a business, and hosts, at its expense, this very useful forum. I don't mind that Pelican doesn't want to give a lot of free advertising to competing sellers of parts for our Porsches. Like most, I can comparison shop when I want to.
Old 11-17-2020, 12:29 PM
ADDvanced's Avatar
Ah that makes sense. I couldn’t even find a drivers side on pelican
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 11-17-2020, 01:34 PM
ADDvanced's Avatar
Okay dudes, here are my ducts, shows how horrible they fit:
https://youtu.be/R1nMMELT8a4?t=671
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 11-18-2020, 07:55 AM
