creaturecat's Avatar
SC with Carrera engine cases
the last of the SC line up used the newer cases.
anyone know if this is a beneficial "upgrade"?
if so, in what fashion?
oiling, head studs, anything? other than the lack of a sump plate.
thx in advance
Old 11-27-2020, 09:03 AM
fresh tooling. i guess there's that.....
Old 11-27-2020, 09:05 AM
and an upgraded oil pump.
Old 11-27-2020, 09:34 AM
Cory M's Avatar
It should also have mounting provisions for the flywheel reference sensors, allowing the retrofit of Motronic injection.
Old 11-27-2020, 09:54 AM
good point Cory M.
apparently the ims is secured in a more modern fashion, as well.
very tail end of production - i wonder how many cars were equipped with the case upgrade?
Old 11-27-2020, 09:58 AM
3.2 case
They were used for last 1/2 of year.Came with oil fed tensioners as well.Stronger case.Best of the SC run.Fred
Old 11-27-2020, 10:05 AM
March '83 was when they started using the newer cases - according to my research. dunno what that means number-wise. mine did not have oil fed tensioners. still doesn't. thx Fred
Old 11-27-2020, 10:21 AM
