| Registered |
				Pad replacement ...glue on brake Sensor?  85 911
			It there a thread on glue on brake sensors?  I wanted to purchase the TVR pads but they dont make REAR pads...  would like to match front and rear.  I dont want to buy Porsche Pads due to the price, using other pads I would need to change sensors to new Glued on Sensors, no longer can I use the notch, clip in type....all new to me!    Not sure how that works... '85 911 | ||
|  12-09-2020, 07:10 AM |
| cycling has-been Join Date: Sep 2004 Location: Jersey Shore
			Can't tell you what adhesive to use. On my 85, I never relied on the sensors to tell me when the pads are low. I disconnected them by clipping the wires in the wheel well, tracing them to the frunk, and reconnected them to each other in the frunk - out of the way. Pads are most efficient when they are more than 1/4 inch thick. Less than that, they heat up quicker, and transfer that heat to the rotors and calipers. Not good. Bill K
				__________________ 73 911T MFI, 76 912E, 77 Turbo Carrera | ||
|  12-09-2020, 09:47 AM |
| Tags |
| brake pads , glue , sensors |
