Yet another engine lift table, but with tilt.
After reading quite a few threads about the merits of using a lift table or a transmission jack for engine removal, I decided that a lift table might work best for my 4-post lift setup. I did however like the fact that some of the trans jacks allowed for tilt.
After stealing a few ideas from this thread, and then dug around in my scrap parts stash and found enough aluminum extrusion and brackets to graft something onto the table. https://forums.pelicanparts.com/porsche-911-technical-forum/681825-transmission-jack-engine-removal.html A piece of 5/8 UNC threaded rod, and some trunnions I knocked up on the lathe... Built a small frame from 1.5" aluminum extrusion, and scabbed some brackets for a pivot... Here's a closeup of the tilt adjuster... Hated using this nice piece of plywood, but it's scrap from a cabinet job... Just need to add some blocks to support the heat exchangers and trans now.
1984 M491 Coupe 2014 Cayman S |
Very cool! The plywood looks great, seal it with a decent urethane coating and I bet it stays clean with wipe-downs after each engine drop.
Garen GNdesignLLC.com - Automotive Art & Sculpture |
R&D guy
Location: the border between the states of inebriation & confusion
Thanks. This is something I could put together relatively easily and I really like the tilt feature. 80/20 is wonderful stuff.
For those who don't know, 80/20 Inc provides the extremely common modular building system parts which have largely replaced weldment frames in many applications. |
I don’t have a welder in my garage anymore, I may need to rethink that decision...
Still here
Beats the two jack tango !
Very nice......
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Looks great. One thing that would make it work a tiny bit better is a knob handle from MSC Direct or Grainger for the all thread. In the heat of the moment, a knob is more convenient than grabbing a wrench or socket and ratchet.
https://www.mscdirect.com/product/details/06927586 https://www.grainger.com/product/KIPP-Hand-Knob-3DGC9 |
Engine table........
Impressive work and like the design. Looks very neat and practical. Good job.
Tony |
That's just beautiful ! Well done. And I thought I was such a smart-guy with my hacked together plywood, transmission jack and harbor freight furniture rollers. Great job.
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
So you use it a couple times then it sits taking up 4 sq feet of precious garage space. You start stacking boxes, part, tools et on top of it. Finally the day arrives 2 years later when you need to use it again. Your in a hurry don’t feel like moving all the crap off it so you use your floor jack with a board on top.
I am my 911's PO
Beautiful work. Should be a dream to use.
Some questions:
I'm loathe to display my crude handiwork next to yours, but it illustrates some considerations:
Again, nice work on the lift. Be sure it is strong enough and stable enough to deal with all the loads it will endure.
1978 SC - original owner 1983 SC - D stock "rescue" track car DECEASED 2015 Cayenne Diesel (rear ended by distracted driver) 2017 Macan (happy wife...) 2016 Cayenne Turbo - tow vehicle and daily drive |
![]() Great post with lots of things to think about... * My handle is the same orientation as your setup, however, I've modded it to lay down so as not to foul the bumper or the rear crossbar of my 4-post. * I've tried to place the pivot point such that there is always a downward load on the jack screw, even when I separate the transmission once it's out. * As far as how much tilt, it goes quite a ways. How many degrees do you estimate it takes with your setup? More later!
1984 M491 Coupe 2014 Cayman S Last edited by Quasimoto; 12-13-2020 at 10:40 AM.. |
I love it , pay no attention to the people that don't do anything in real life . I have been thinking of something similar for my rolling table . You have inspired me . Maybe I'll add a servo motor as to adjust the tilt as it drops out .
Thanks Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains Last edited by icarp; 12-13-2020 at 01:24 PM.. |
I am my 911's PO
Quasimoto,
RE: tilt I use a small bottle jack with 6" of travel to elevate the back end of the platform. That is not enough tilt, so I relocate it mid-process to bear on a 4" block (see photo of underside). Consequently, I get about 10" of travel acting over a 16-21" base (moving to the block shortens the distance from the jack to the pivoting crossbar supported by jackstands). Supports One thing I especially like about your design is that all the support points (frame pivots and elevating screw) control motion both up and down. Mine provides upward support only, so I have to be very careful about tilting, especially laterally because there's nothing to hold the other side down. (The Pyramids have held together just fine relying only on gravity, but then they're not being tilted and jostled to align with an easily cross-threaded transmission mount. ![]() Originally I intended to use a jackscrew similar to yours, but I can't machine parts like the trunions you made (very nice). I use ratchet straps to limit movement, but I'm going to steal some of you design elements for more positive control. Stability We're both using three points of support, so the key is keeping the center of gravity (CG) inside the triangle. The CG is where the 500# of drivetrain acts on the platform. I went with a wide base near the CG to control lateral movement; your design puts the CG closer to the lift screw. My concern/question is how close does that bring the CG to the edges of the support triangle? Where the drivetrain sits relative to the supports is key. I visualize this as standing on/near the seat of a tricycle versus standing on/near the handlebars; the chance of tipping sideways is less near the wheels. This diagram is not to scale, but illustrates my point: ![]() IMO the ideal would be a broad, nearly equilateral triangle with the CG safely centered, as in the middle diagram. Top view of my support platform showing blocks to engage specific features on the crankcase. I remove the exhaust first, so this engages the crankcase directly Bottom view showing crossbar supported by jackstands and sockets for the bottle jack. |
Heck, I’m only 5 not 71!
![]() The jack and jack stands are essential tools in the garage and I have the space to store them. Due to a blown air box I will be dropping the motor in a few days with the same dolly and a newer jack and jack stands. The dolly was based on someone else's design that I found in 1998. Granted when lowering or raising the motor you have to have the right balance point or it could go terribly wrong. I do have enough confidence to be able to find that perfect balance point with a little hand holding to keep the motor steady. You need to make a double check that all cables and hoses are disconnected before lowering ![]() ![]()
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
Enginerd
Project support projects
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2017 GT Silver Turbo S, 2020 British Racing Green Macan GTS Gone but not forgotten: 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS IG: @pcar911fan |
Had a few minutes to finish up the top today...
Still here
Depends on how high the rear end is.
Probably need more ... 0.4-0.5 radian. |
your 4-post...
Quasimoto, what brand of 4 post do you have and what's the spread between the inner rails of the treads?
1985 911 Targa 2001 996 C2 2009 997 C4S |
I dropped my engine between my ramps on my Bendpak HD9-XW 4 post lift a few years ago for my 83SC
Thread Tools | |
Rate This Thread | |
