Name This Part
Hi all, I'm just digging into a new-to-me 1980 SC and starting with the basic. Have the idle and timing set and now looking to sort out various surges that are still occurring at idle. I can spot 2 likely culprits, the first is what I would assume is a vacuum assembly sitting on a bracket mounted over the top of cylinder 3. I cannot find this part in the Service Manual or in any PET diagrams, so turning to the Pelican experts for some guidance on what this is and what it should be connected to.
The second issue is simply an open port on the air cleaner assembly. From what I can tell there is simply supposed to be a plug here, and it's missing. Plus doesn't seem to be available any longer, so I'm planning to just put a generic vacuum plug over it.
thanks!
Larry
Old 12-29-2020, 01:40 PM
It’s a bit strange that the item isn’t in PET, could you take a picture?
Old 12-29-2020, 01:43 PM
ROW '78 911 Targa
timmy2's Avatar
US or a euro car?
Reply here and there a few times to be able to post photos...
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-29-2020, 01:47 PM
Yes, there were photos in the original post (wrapped in [IMG] tags) but they don't seem to be appearing.
Let me try attachments...
Originally Posted by timmy2 View Post
us or a euro car?
us
Old 12-29-2020, 01:48 PM
Not sure but I think the nipple on the air cleaner box is for the charcoal canister.
Don't know what the vacuum switch is for.
Old 12-30-2020, 07:50 AM
Designer King
Paulporsche's Avatar
That part is the thermovalve. It closes off vacuum to the lower chamber of the WUR for about the first 30 seconds during startup when temps are under 20C so that there is additional enrichment for starting.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 12-30-2020, 08:06 AM
Designer King
Part 17A
Paul
Old 12-30-2020, 08:16 AM
Reiver
Reiver's Avatar
You can simply plug the air box opening....the other is a working part of the CIS.
De Oppresso Liber
Strength and Honor 5th Legion
Old 12-30-2020, 08:30 AM
